On cold mornings, when I try to start, it clicks...why?
Old Jan 17, 2004 | 01:45 PM
SOHCMAN's Avatar
Default On cold mornings, when I try to start, it clicks...why?
More specifically, it wont start the first time, it just clicks loud and maybe turn over 1/2 a turn, then I release the key to on position and try to start again and it fires right up?
Bad starter or battery?
thanks, sohc
Old Jan 17, 2004 | 01:55 PM
SOHCMAN's Avatar
Default Re: On cold mornings, when I try to start, it clicks...why? (SOHCMAN)
um, ok, so somehow this post got the wrong title to it (SORRY!!) and it wont let me delete it because its the first post... The question I asked is real though.. how can I change the title?
thanks, and sorry again!
sohc
Old Jan 17, 2004 | 06:41 PM
brian2903's Avatar
I've the same the problem when starting my car
Old Jan 17, 2004 | 07:01 PM
jwogen1's Avatar
how is the car in regular temperatures? starting wise?
Old Jan 17, 2004 | 07:02 PM
jwogen1's Avatar
battery may not have enough cold cranking amps.....
Old Jan 18, 2004 | 01:45 AM
accordfreak's Avatar
Default Re: On cold mornings, when I try to start, it clicks...why? (jwogen1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwogen1 &raquo;</TD></TR><TR><TD CLASS="quote">battery may not have enough cold cranking amps.....</TD></TR></TABLE>
would putting the battery in the trunk affect the cold cranking amps?
Old Jan 18, 2004 | 06:31 AM
jwogen1's Avatar
Default Re: On cold mornings, when I try to start, it clicks...why? (accordfreak)
there is a number on all battery types that states the amount of cold cranking amps, so i dont think so....better batteries/different types have more cold cranking amps and so forth.
Old Jan 18, 2004 | 07:17 AM
Nick H's Avatar
New User
i have the same problem, if you figure it out lemme know
Old Jan 18, 2004 | 09:23 AM
The_Todd's Avatar
Farts in the shower
I don't think putting the battery in the trunk would really do much for ya for CCA, in Colorado it gets damn cold and I think I have a 500 some CCA on my battery, there are 2 numbers on the battery Cranking amps and cold cranking amps....basically the cranking amps is what it draws to crank a normal temp car (not cold) and the CCA is what the rating is for it to start a cold car (ie tempurature) I could suggest checking your grounds and seeing what CA/CCA your battery is, in colorado I don't use anything below 400-500 CCA. Also pop those lids on the battery and make sure there is enough water in them. Hope this helps.
Old Jan 18, 2004 | 10:25 AM
GrandMarkie's Avatar
Same thing just happened with my mom's car. It eventually took 4-5 trys when it finally started. The first 4 times it just clicked. Ended up being her starter. Cost her $270 including labor from the dealership. Best of luck.
Old Jan 18, 2004 | 11:49 AM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCMAN &raquo;</TD></TR><TR><TD CLASS="quote">More specifically, it wont start the first time, it just clicks loud and maybe turn over 1/2 a turn, then I release the key to on position and try to start again and it fires right up?
thanks, sohc</TD></TR></TABLE>
It sounds to me like you are having a connection problem. I would remove the battery cables and clean the inside of the ends and the posts on the battery also.
If this does not fix the problem ... a new starter may be needed.
Old Jan 19, 2004 | 08:48 AM
Monkey Fing a Coconut's Avatar
Default Re: On cold mornings, when I try to start, it clicks...why? (GrandMarkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrandMarkie &raquo;</TD></TR><TR><TD CLASS="quote">Same thing just happened with my mom's car. It eventually took 4-5 trys when it finally started. The first 4 times it just clicked. Ended up being her starter. Cost her $270 including labor from the dealership. Best of luck.</TD></TR></TABLE>
ya shoulda gone to autozone and picked one up for $120 and installed it for her...its actually more than that but they match prices, i found a place for $120 after i had already installed the autozone one, plus lifetime warrenty
Old Jan 19, 2004 | 10:39 AM
JimBlake's Avatar
I'll vote for bad connections somewhere in the starter circuit. Dirty battery posts, dirty connection where the wire itself connects to the battery clamp? Same story at the other end of the cables. Don't forget the big ground wire from engine/tranny to the body. Corrosion anywhere can do that.
love_my_ekcoupe
Jan 26, 2010 08:20 PM
dohc_profile
Oct 12, 2007 11:32 PM
jdmkrazie
Nov 22, 2005 07:15 PM
badazzaccrd
May 29, 2004 10:05 PM
integranator
Jan 12, 2003 10:52 AM
