Which OEM FPR will fit a 99 civic si? I got an ls one from the junkyard but the return won't fit.
Wow, long title
Which OEM FPR will fit a 99 civic si? I got an ls one from the junkyard but the return line won't fit. It is way bigger then the hose is. Any OEM ones likely to work that I can pic up at the local yard?
you can use the ls one, just make an adapter for the return line.
note:fuel pressure will be a little different
TwistedSI
Apr 21, 2003 10:09 PM
