1995 Honda Accord EX, Rear Rotor Replacement
Old Jan 16, 2004 | 09:58 AM
vtec4gcivic's Avatar
Default 1995 Honda Accord EX, Rear Rotor Replacement
I know on the front disc you have to press out the wheel bearing in order to replace the rotor. Is that true for the rear as well? In need to know as soon as possible.
Old Jan 16, 2004 | 10:26 AM
Hondaaccordvtec's Avatar
Default Re: 1995 Honda Accord EX, Rear Rotor Replacement (vtec4gcivic)
The rear rotors are held on by 2 screws. You will need to get an impact screwdriver in order to even budge the screws.
Old Jan 16, 2004 | 10:29 AM
Default Re: 1995 Honda Accord EX, Rear Rotor Replacement (Hondaaccordvtec)
are you sure its 2 and not 4?
Old Jan 18, 2004 | 12:27 PM
mwkirchner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4gcivic &raquo;</TD></TR><TR><TD CLASS="quote">are you sure its 2 and not 4? </TD></TR></TABLE>
Yes ... it is 2 screws ... NOT 4. The 4 you may be speaking of would be the lug nuts. The screws that are being referred to in the thread are on the face of the rotor itself.
The caliper assy would have to be removed as well to get the rotor off the hub. It is held on in the back with 2 bolts that require a 14mm wrench to remove. Once it is removed (the caliper that is) then the rotor will come off. You may have to use a hammer on the face of the rotor (not the surface where the pad makes contact ... but the area where the screws are) to get it to break loose. More times then not the rotor will be rusted to the hub.
forevernewbie
Aug 7, 2007 10:55 AM
dwjgoblue
Sep 22, 2005 04:14 AM
99electron_blue_si
12
Aug 3, 2005 08:18 AM
Kalokohan
Apr 11, 2003 06:23 PM
integra7
Dec 4, 2001 12:41 PM
