Need some advice. Might buy an Integra.
Old Sep 30, 2001 | 06:01 PM
_Shadow_'s Avatar
New User
Default Need some advice. Might buy an Integra.
Hey whats up peeps? I'm in the process of selling my 2000 Si. I'm selling it because I basically cant afford it any longer. I'm tired of the car payment.
I've been looking for something a little different and my eye caught sight of an integra. I like! I'm really into speed now and dont really care about all that other stuff. I dont think I can afford a GS-R cause they are kinda pricey but either way I am looking for an integra that will haul ***. I've always wanted to do an engine swap, so that is not out of the question. So would it be easier and cheaper to just buy a base model integra and do an engine swap, maybe a b20 bottom end and B18c top? I'm not sure how all this engine swapping stuff works but I was told you can have a B20 bottom with a VTEC head? Someone care to straighten this mess out? I'm gonna turbo this car so I need the best setup for turbo. So should I just start out with a GS-R and do the B20 bottom (if possible) and run boost, or should I just start with a base model integra and start from scratch with the engine? Help me out guys. I'm new to this. Please dont tell me to do a search either!!!! Thanks for all your help.
Old Sep 30, 2001 | 06:31 PM
FAST94GSR's Avatar
New User
Default Re: Need some advice. Might buy an Integra. (_Shadow_)
It depends on how much you are gonna boost and how much power you want to make. You can find 94 integras ls's and rs's for cheap. You can throw a drag 3 kit run 10 lbs and run 13's on slicks. The VTECS ie GSR models respond better to turbo chargin, they typically make 30+hp than a non vtec.
Whatever route you go it really depends on your budget, what your preference is , so on and so on.
I say establish a budget and determine how fast you want to go first, then you can sort out the nitty gritty details on which engine to go with.
Old Sep 30, 2001 | 06:44 PM
_Shadow_'s Avatar
New User
Default Re: Need some advice. Might buy an Integra. (FAST94GSR)
That helps out alot . I want to run 12's maybe 13's. I want this car to be my project car. So I'll probly have it around for awhile. I dont really have a set budget yet. I wanted to find a car for around $6000 give or take and then build from there. The car cannot cost over $8000 but what I will invest into the car after I buy it will be any amount. So with that in mind. I've been looking around for some used integra gsr's. I can probly find a good condition 96 for about $7000.
I'll probly use a custom turbo setup. This car will be daily driven so nothing too crazy. Will I need to build the internals to break into the 12's? What would you recommend with these questions being answered.
Old Sep 30, 2001 | 06:55 PM
FAST94GSR's Avatar
New User
On a GSR with about 6-8 lbs of boost on stock internals you should hit 13's. To hit the 12's (high 12's) you'll have to boost a little higher like 10-12lbs. I don't recommend boosting that high on stock internals, that is threshold limit for breaking. It can be done as long as you have the proper fuel management BUT I don't advise it.
If you want to hit 12's all day with reliability get some pistons and rods (Crower and JE 9:1) then get a hondata system. You can boost safely up 18 lbs Besides that you'll need a 3 inch exhaust, and a good clutch, boost controller, bigger injectors,turbo timer, ya ya.
Off the top of my head if you can find a GSR for 7000 it will cost like another 4-5000 for all the stuff I mentioned. You should be able to do mid-low 12's with trap speeds in the 115 range.
Old Sep 30, 2001 | 07:07 PM
owen_the_soyboy's Avatar
it would be cheaper to start with a civic cx, a 92 would be cheapest.
I bought mine for 2000 bux and it runs like a champ.
over the winter I will be hybriddign and rallycrossing it.
my integra even as a 94 was a 9000 dollar entry fee for mods to add ontop of that $$, so the civic is a much cheaper option if you will be replacign a lot of parts.. sus, brakes, motor, interior, so on and so on....
Old Sep 30, 2001 | 09:23 PM
Isaac's Avatar
New User
Default Re: Need some advice. Might buy an Integra. (owen_the_soyboy)
Exactly what I was going to say. If you know how to install the engine into a different chasis then you will be fine. I was considering doing a swap into a hatchback, but the trouble to me wasn't worth it since I needed a car. I didn't know what problems I would run into in the future and I wasn't about to dish out the money to have a shop install the engine. Soo...I went with my car which I'm definitely satisfied with. Anyways, HYBRID for inexpensive POWER
yungevo
Mar 18, 2014 06:31 AM
JuniorCMK
Jul 14, 2009 09:28 PM
racereaper7
May 5, 2006 08:53 PM
