d15 cam
Old Jan 15, 2004 | 07:45 PM
TylerB's Avatar
Default d15 cam
Recently tearing down my head, i found my cam was all eat up, is there any place that makes aftermarket cams for a d15b2?
Old Jan 15, 2004 | 08:35 PM
Whitfield Inc.'s Avatar
Default Re: d15 cam (94prelude)
In the past JG had regrinds availble, im sure we could help you locate them
Old Jan 15, 2004 | 10:10 PM
SOHCwarrior's Avatar
drop in an si cam and adj. camgear, slightly more aggresive and cheap
if you want an aftermarket one though, check out exospeed.com
Old Jan 16, 2004 | 06:42 AM
static_signal's Avatar
88 to 89 si crx cam fits right up dont need a cam gear......
Old Jan 16, 2004 | 10:37 AM
Default Re: d15 cam (static_signal)
you need a cam gear because the timing is a half tooth off due to the shorter block, it will run with out a cam gear but will run alot better with it.
check out mista bone's camparison (he is the orignator of this mod)http://home.cinci.rr.com/mistab0ne/dyno.html
Old Jan 16, 2004 | 01:47 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: d15 cam (SOHCwarrior)
depending on how "eat up" your cam is maybe you can have it reground. call delta cams, the # is on here...http://www.deltacam.com
Modified by fastcrxsi90 at 7:52 PM 1/16/2004
Old Jan 16, 2004 | 04:45 PM
Kendall's Avatar
A lot of cam companies will custom make you a cam, all you have to do is ask, and pay.
Old Jan 16, 2004 | 06:36 PM
TylerB's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">A lot of cam companies will custom make you a cam, all you have to do is ask, and pay.</TD></TR></TABLE>
will i pay out the *** for a custom grind?
Old Jan 16, 2004 | 07:40 PM
Jimmy's Avatar
Global Moderator
Default Re: (94prelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">
will i pay out the *** for a custom grind?</TD></TR></TABLE>
yes you will
Old Jan 17, 2004 | 07:58 AM
the deltacam was about $100 with the shipping to and from.
Old Jan 17, 2004 | 08:01 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94prelude &raquo;</TD></TR><TR><TD CLASS="quote">will i pay out the *** for a custom grind?</TD></TR></TABLE>
It depends on which company you get. Some companies are small and will make you custom parts for a low price, probably $100-$200. Larger companies, like Crower, Crane, etc, would probably charge upwards up $300 or more for a custom cam.
Old Jan 17, 2004 | 08:24 AM
blah13's Avatar
Wil from Exospeed says he's taking b2 cams for regrinds and hes got a decent sale goin on, 25% off roughly. So about 150 for a better than stock profile.
Avi
Mar 27, 2007 04:42 AM
ultimatehonda
Nov 20, 2005 04:11 PM
EJ8 GSR-T
Jun 2, 2005 10:58 AM
cadougherty_67
Mar 6, 2005 06:11 AM
Brewer
Jan 13, 2004 10:58 AM
