my car gets no spark and no fuel injection firing
Old Jan 15, 2004 | 06:08 PM
civicnightmare's Avatar
Default my car gets no spark and no fuel injection firing
my car tries to turn over but theres no spark and the fuel injectors arent firing ive checked everything twice im just pissed
Old Jan 15, 2004 | 06:09 PM
GeorgeJetson's Avatar
Default Re: my car gets no spark and no fuel injection firing (civicnightmare)
Same problem im having, either the under hood fuse box, or main relay
Old Jan 15, 2004 | 06:13 PM
doublejz's Avatar
Default Re: my car gets no spark and no fuel injection firing (georgejetson)
check your main relay
Old Jan 15, 2004 | 06:53 PM
Hater's Avatar
i third the relay
Old Jan 15, 2004 | 06:55 PM
Default Re: (Hater)
WE did the main relay on my ride and that didnt help, we traced it back to the under hood fuse box
Old Jan 15, 2004 | 06:56 PM
W C L's Avatar
ecu fuse? ecu plugged in???
Old Jan 15, 2004 | 06:59 PM
visionsOFmadness's Avatar
ecu might be bad
Old Jan 15, 2004 | 07:10 PM
Default Re: my car gets no spark and no fuel injection firing (spoonspeed)
my ecu worked before so im pretty sure its not that ill check the main relay but we checked the fusebox under the hood and all the fuses came up as good ill recheck them though i am getting a scan tool tomorrow hopeully ill have answers then wheres the main rlay at im a novice
Old Jan 15, 2004 | 07:21 PM
W C L's Avatar
your ecu ground on top of thermostat housing????
Old Jan 15, 2004 | 07:28 PM
Default Re: my car gets no spark and no fuel injection firing (W C L)
there was 2 grounds on the old engine one on the head that goes to the frame on the driver side front side of the head and then one coming off the tranny that bolts to the frame on the passenger side of car under hood
Old Jan 17, 2004 | 12:28 AM
91EFate's Avatar
having the same problem on my crx, except i hear a ticking noise coming from my eacv when i put the key in the ignition and turn it to acc. also i just put in a new dizzy but still no spark.....however i have power to the coil. any idea whats wrong?
Old Jan 17, 2004 | 03:54 AM
2lua's Avatar
Default Re: (avirex_man_2000)
got fuel in the tank?
check fuel pump to see if it working by turn the ingition key on
check for ground.
what motor is in yoiur car?
need more info
Old Jan 17, 2004 | 05:43 AM
flat-blk-HB's Avatar
Default Re: (2lua)
check the ground on your thermo housing....
Old Jan 17, 2004 | 06:52 AM
m3dia_lab's Avatar
i had this problem, check your distrobter(Spelling?)
Old Jan 17, 2004 | 07:03 AM
951's Avatar
951
Default Re: (m3dia_lab)
doesnt explain the lack of fuel though...interesting, i had the same **** go on with my car, it still does it everyonce in a while, like its flooded...but obviously FI cars shouldnt flood.
jdmgsr420
Honda CR-V & Element
35
Mar 4, 2012 06:10 AM
f20cmx5
11
Mar 25, 2011 04:57 PM
91b18a1ls
Nov 23, 2010 11:29 AM
mihaelrosas
Jun 8, 2007 04:27 PM
GsrTurboCRX88
Dec 12, 2006 04:42 PM
