b18c1 from 97 gsr into 97 civ dx
which parts can I use from the gsr and what will I have to buy/ find? to make th eswap happen. The gsr was totaled in the rear. whole front end good. axles, front spindles, exhaust, gsr shift linkage,coolant hoses ???? help!!
Well you'll need the 99 - 00 Si rear and drivers side mounts.
Use the GSR axles and shift linkage.
( you might need a new hose or clamp or something here and there too )
Then use your harness from the stock engine on the new gsr engine. Find out which sensors are left and run the wires from those sensors to the ECU.
Tada!
Tada!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Don't forget to get the ECU, and to wire up the VTEC properly.</TD></TR></TABLE>
Yes!! exactly... almost forgot that..
wylls
Jan 18, 2004 07:59 AM
