can i use an automatic crank?
Old Jan 15, 2004 | 10:22 AM
gumbybum's Avatar
Default can i use an automatic crank?
can i use an automatic ls crank in a ls manual motor? do they bolt to the flywheel the same? i did a search and couldn't really find anything so i need a little help. i don't really want to pay a lot of money for a crank when there are two at pic-n-pull. thanks guys..
Old Jan 15, 2004 | 10:36 AM
mmuller's Avatar
Mad Scientist
Default Re: can i use an automatic crank? (gumbybum)
they are the same
Old Jan 15, 2004 | 10:40 AM
92civeg's Avatar
Default Re: can i use an automatic crank? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">they are the same</TD></TR></TABLE>
interesting
Old Jan 15, 2004 | 01:44 PM
ultimatehonda's Avatar
As long as the motor is a LS then it will work....the crank is the same regardless of transmissions.
Old Jan 15, 2004 | 04:29 PM
doublejz's Avatar
Default Re: can i use an automatic crank? (ultimatehonda)
what he said
Old Jan 15, 2004 | 04:53 PM
Kendall's Avatar
Also the crank from the B20A1 will fit, but then you need custom rods.
Old Jan 15, 2004 | 05:02 PM
gumbybum's Avatar
thanks guys that will save me a lot of money and time. you guys are the greatest i love HT
Old Jan 15, 2004 | 07:29 PM
c1civic's Avatar
can interchange without a problem
Old Jan 16, 2004 | 05:24 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbybum &raquo;</TD></TR><TR><TD CLASS="quote">can i use an automatic ls crank in a ls manual motor? do they bolt to the flywheel the same?...</TD></TR></TABLE>The crank is the same, but the flywheel bolts are different. The bolts holding the thin flexplate of an auto aren't as long as the bolts for a thicker flywheel. But the crank itself is the same.
Old Jan 16, 2004 | 03:19 PM
sick64nova's Avatar
Default Re: (Kendall)
same rods all pr4
EGCoupeVtec
Jul 23, 2008 07:40 AM
e jay one
27
Jun 6, 2005 11:36 PM
takumi604
Feb 9, 2005 09:32 AM
B16A1-EF9
Nov 20, 2004 08:01 AM
JDMkidGSR
Aug 18, 2004 04:15 PM
