ignitor...where can i get one?
Old Jan 15, 2004 | 08:23 AM
10seceg's Avatar
Default ignitor...where can i get one?
Ive got an ignitor out of a 95 civic ex but it doesnt looks like it is going to work...ive been looking for a new one but cant find one anywhere...does anybody know where i might be able to get one? thanks!
Old Jan 15, 2004 | 08:58 AM
egsleepercivic's Avatar
about $200 from dealer, not much cheaper from discount auto part stores
Old Jan 15, 2004 | 09:59 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: (egsleepercivic)
wrong, do a search on Google.
i have found one for my car for under $40.
Stan
Old Jan 15, 2004 | 10:49 AM
10seceg's Avatar
Default Re: (Stan D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stan D &raquo;</TD></TR><TR><TD CLASS="quote">wrong, do a search on Google.
Stan</TD></TR></TABLE>
done the search on google plenty of times and cant find any...could you show me a link? thanks!
Old Jan 15, 2004 | 12:12 PM
Default Re: (10seceg)
hmm, pardon, the cheapest i found is 140...
i suppose D16Z6 igniter is a different design.
http://shop.hondapartstore.com/?make=HO&year=1995
Stan
Old Jan 15, 2004 | 01:38 PM
10seceg's Avatar
k thanx man!
Old Jan 16, 2004 | 06:58 AM
10seceg's Avatar
k...got a new ignitor for only 80 bux and now im still not gettin any fire...ive got a new coil.....new ignitor...what else could be wrong?
Old Jan 16, 2004 | 08:07 AM
hondatim's Avatar
when, you turn the key on with engine off, does CEL come on. If not, may have ECU issue.
Old Jan 16, 2004 | 08:10 AM
hondatim's Avatar
Default Re: (hondatim)
Also, have you checked to see if you're getting signal to ignitor from ECU while cranking? Will need a logic probe or graphing meter for this.
Could you have the wires connected incorrectly? Not questioning your work, but I have seen seasoned technicians do this and not think about it...
Old Jan 16, 2004 | 08:11 AM
10seceg's Avatar
i know i can reset the ECU but dont know how...what could be wrong w/ it and how do i reset it?
Old Jan 16, 2004 | 08:13 AM
10seceg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatim &raquo;</TD></TR><TR><TD CLASS="quote">
Could you have the wires connected incorrectly? Not questioning your work, but I have seen seasoned technicians do this and not think about it... </TD></TR></TABLE>
i thought about it but it looks like its fine...if i had a diagram i could be exact ya know......
Old Jan 16, 2004 | 08:15 AM
hondatim's Avatar
to totally reset ECU, just remove both battery cables from battery and touch them together to discharge system totally and reconnect cables to battery. Resetting ECU will probably not help. You need to check the signal to and from the ignitor that I talked about earlier.
Hope this helps
BTW, like your name. What's it run in the quarter?
Old Jan 16, 2004 | 08:19 AM
10seceg's Avatar
BTW, like your name. What's it run in the quarter?</TD></TR></TABLE>
...a gentleman never asks and a lady never tells... but thanx for the advice.. my stepdad is a big electronic freak i just didnt want to have to bother him... what kind of signal should i be gettin on the meter...?
Old Jan 16, 2004 | 08:46 AM
Katman's Avatar
what happens, exactly, when you try and start your car?
and have you performed any engine mods or added any electronic components to your engine (MSD, etc) ?
Old Jan 16, 2004 | 08:58 AM
10seceg's Avatar
Default Re: (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">what happens, exactly, when you try and start your car?
and have you performed any engine mods or added any electronic components to your engine (MSD, etc) ?</TD></TR></TABLE>
well when i try to start it i just turns over normal like its wanting to start...but im not getting any spark..got fuel and got comp. all the way accross...just no spark... this is the second time this has happened but last time it was the coil so i ordered an MSD coil (again) and bought a new ignitor thinking that would solve my problem but im just simply not getting any spark... and engine mods..well i have a few but only an MSD coil for my ignition..
Old Jan 16, 2004 | 09:09 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seceg &raquo;</TD></TR><TR><TD CLASS="quote">
well when i try to start it i just turns over normal like its wanting to start...but im not getting any spark..got fuel and got comp. all the way accross...just no spark... this is the second time this has happened but last time it was the coil so i ordered an MSD coil (again) and bought a new ignitor thinking that would solve my problem but im just simply not getting any spark... and engine mods..well i have a few but only an MSD coil for my ignition..</TD></TR></TABLE>
aww boy..you gotta MDS eh ? I bet that thing is the culprit. You *might* have killed your ecu somehow/someway. I've had a couple past customers send me their ecu who had an MSD unit on their car, they say their car wouldnt start and they thought the problem could be fixed by reprogramming their ecu.....nope....the MSD blew *something* out inside the ecu. I was never able to find out what exactly, but the MSD definitely cause the issue, and I'm thinking the same happend to you. But before thinking worse case scenerio...have you checked your spark plugs? Usually dirty/fowled up spark plugs are culprits in a car not being able to start/hard starting.
I was gonna say, try a different ecu in your car, but you -might* damage that one! If your motor is mostly stock (no internal engine work) and naturally aspirated (no NOS or turbo), I say CHUCK the MSD unit. It's really unnecesary for a stock Honda engine.
Old Jan 16, 2004 | 09:17 AM
10seceg's Avatar
well dude...im runnin boost through a turbonetics t3/t04e but ya know..if you think i need a new (factory coil) and ECU ...damn its expensive but i guess ill have to try it
Old Jan 16, 2004 | 09:31 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10seceg &raquo;</TD></TR><TR><TD CLASS="quote">well dude...im runnin boost through a turbonetics t3/t04e but ya know..if you think i need a new (factory coil) and ECU ...damn its expensive but i guess ill have to try it</TD></TR></TABLE>
ok, your turbo equipped.
Usually running MSD unit with a turbo is a good thing.
Hmm, hard call, but I say you try a different ecu in your car and see what happens, maybe try a 92-95 DX ecu and see what happens. Or unwire the MSD and fully off the stock ignition to see if the MSD is the culprit along with running a different ecu.
what sucks, is this might not even be the issue, maybe something small & retarded is making your car not start......kinda hard to diagnose.
Old Jan 16, 2004 | 09:34 AM
10seceg's Avatar
what sucks, is this might not even be the issue, maybe something small & retarded is making your car not start......kinda hard to diagnose.</TD></TR></TABLE>
I know...thats what pisses me off..ive been working on the bitch for the paste month every damn day and its starting to royally **** me off... I fig. putting in the New MSD coil and ignitor would be the problem...but its obviously not.. it usuallly is something stupid and small but makes a world of difference..if you might have anymore advice...please post it up....&lt;---and that goes for anybody...im almost in a desperate mode to get it running
Old Jan 16, 2004 | 01:05 PM
10seceg's Avatar
ttt guys....i reallllly need some help on this!!!
Old Jan 16, 2004 | 07:44 PM
10seceg's Avatar
bump for some much need advice!
Old Jan 17, 2004 | 07:59 PM
mwvnos's Avatar
bump...needs his car runnign asap!! thanx
mikelax125
Honda Civic (2001 - 2005)
Apr 24, 2007 08:43 PM
SPOONfed-Rex
Feb 19, 2007 01:14 PM
J9D6M
Nov 2, 2006 09:03 AM
Andrew01
Oct 22, 2003 08:45 AM
