does someone have a compressor map for sc34
Old Jan 15, 2004 | 07:50 AM
dc2_and_ef's Avatar
Default compressor map for sc34 (art or geoff)
can anybody share this with the .48 ar if it matters? also in yalls oppinion would you put the on a b16 84mm bore? 8.8:1 with sufaced block and surfaced head?
Modified by dc2_and_ef at 5:07 PM 1/15/2004
Modified by dc2_and_ef at 5:12 PM 1/15/2004
Old Jan 15, 2004 | 08:54 AM
TheShodan's Avatar
Moderator
Default Re: compressor map for sc34 (dc2_and_ef)
Here's your map: You'll probably need to read up on the baest way to plot your application.. You'll need a lot of boost considering you dropped your compression so low on a B16, it's hard to tell what it will do.. But you will need to up the boost.
http://www.turbofast.com.au/FlowTO4E.html
Old Jan 15, 2004 | 08:57 AM
dc2_and_ef's Avatar
thanks alot man. now i can take this to endyne to have them work my head over art what do you think with this setup, and that turbo?
Old Jan 15, 2004 | 12:40 PM
dc2_and_ef's Avatar
ttt
Old Jan 16, 2004 | 08:20 AM
dc2_and_ef's Avatar
bump for o more replys
ko_gsr
Mar 15, 2013 02:54 AM
accord_raffi
Engine Management and Tuning
Dec 24, 2008 03:04 PM
Stop the Beast
Mar 9, 2006 07:54 PM
sweettooth
Apr 27, 2002 08:33 AM
