how many people are usig holset h1c
hey im currently building my gsr up for boost and i am going to run a holset h1c im just curious what kinda numbers people were seeing with this turbo
Moderator
Re: how many people are usig holset h1c
Head to the "Holset Users, UNITE" forum.
https://honda-tech.com/forums/forced-induction-16/holset-users-unite-1225182/
You'll find answers there. BEWARE, its long, but informative.
Who is Mr Robot?
Its not the best choice, very narrow compressor map, small efficiency island that's in the lower part of the map and stops at 1bar of pressure.
Also, its only 71% efficient at most, you'll be in the lower 60s all of time. Map only flows to 36kg/sec at its limit so don't expect magical power. You'll more than likely have a huge issue with surge and choke, due to how narrow and inefficient the map is.
Couple that with a huge turbine wheel and even bigger turbine housing and you have a very laggy car that makes very little power
OP,
I run a H1C, here's my setup.
Drivetrain-
Block- B18C1,
OEM gsr crank
GSR Eagle rods
81.5 mm 11.0:1 CP pistons (PTW 0.0045")
OEM main bearings (bearing clearance 0.002" except the middle which is 0.0022")
ACL rod bearings (bearing clearance 0.002")
Head- B16A2, stock port, stock valves
VT- Supertech springs H1002D, and 2002 rsx type-s retainers
Cams- Pro2 intake and Blox C exhaust
TB- Professional Products 68 mm
Ignition- Stock Dizzy, wires, and NGK 8's
Fuel Delivery- Walbro 255 and ID1000
EMS- OBD-1 converison, chipped P28, neptune'd
Trans- S4C, cable to hydro bracket, and CC stg 4 clutch
Turbocharger-
Turbo- Holset H1C model 3531456, 18 cm^2 exhaust housing with 3" v-band (DIY)
Manifold- Mini-ramhorn 1.5" sch 10 fitting (DIY), (Importdps)
Wastegate- Tial 38 mm
Oiling- GE Vtec sandwich plate, -4AN stainless braid (feedside), 12 mm x 1.5 to -4AN flare, -10AN stainless braid (return side)
Hotside charge piping- 2.5" Aluminum piping (Dynamic Performance)
Coldside charge piping - 3.0" ALuminum piping (Dynamic Performance)
Intercooler- Precision 600 Hp (Importdps)
BOV- Tial 50 mm
Map sensor - GM 3 bar
Downpipe- 3.0" stainless steel (IMW)
Exhaust- 3.0" stainless steel (Synapse Motorsports)
Here are the dyno plots.
Cast piston at 11 psi vs forged at 14 psi.
Boost plots: 11 vs 14 psi
Lol, it does not work.
Drivetrain-
Block- B18C1,
OEM gsr crank
GSR Eagle rods
Turbocharger-
BOV- Tial 50 mm
thanks for all the info, im not looking for crazy number either so well see if this turbo suits what im looking for if not i can always upgrade
Who is Mr Robot?
You can see my concern with the turbine side is on that dyno sheet. That same wheel with a smaller exhaust wheel, more suited for gas applications would spool wonderfully.
There are much better Holset combinations out there, look for HX35 7-blade with a 12cm2 housing.
Even a HY35 if you have modest power goals
