Speedo problems...weird stuff.
Old Sep 30, 2001 | 09:17 AM
fowler!'s Avatar
Default Speedo problems...weird stuff.
Okay, this seems wierd to me..
I have an Si cluster in my EK Dx. For some reason now, the speedo seems to jump around at certain points. One when the car is pretty cold and two when I'm WOT.
Here is what I thought: I had alternator problems a month or so back...I had to charge my car everyday for a month straight. So, I'm sure my battery is shot to hell. I notice that when I'm driving my headlights dim and light up at certain throttle positions. Maybe, for some odd reason, this is also effecting the speedo.
Here is what my friend thinks: A week or so ago (when all this began to happen) we drove the car pretty dang fast. The speedo was pinned...could it be that the little motor inside was trying to go higher but couldn't due to the limitations of the cluster? Seems to make some sense. Still not sure. He also said that VTEC wasn't working when he layed into it...
Soooo, we took out the cluster and put the stock speedo in (DX speedo in Si cluster). Everything seemed to work fine. VTEC was kicking in...pulling like usual. Problemfixed? Later that night I got on it again and it started jumping around again.
Soo, now I'm stumped. Anyone out there have a clue? Calibration?? ECU???
Old Sep 30, 2001 | 04:41 PM
Homer_Simpson's Avatar
Default Re: Speedo problems...weird stuff. (fowler)
VSS = Vehicle speed sensor....
Mine did the same thing until i changed taht....
that could be the problem...
Old Sep 30, 2001 | 04:46 PM
bigTom's Avatar
Default Re: Speedo problems...weird stuff. (*****rAcEr)
yup... mine did the same... the vss sensor... its on your tranny... towards the back of it... unplug it and see if everything is well for starters... a pin corroded on mine and i had to replace it
kaboomwoom
Mar 12, 2008 01:06 AM
hondaboy4life
Oct 9, 2006 09:35 AM
92eg6lsvtec
Aug 27, 2006 11:59 PM
BumpinVTEC
May 21, 2004 11:23 PM
CustomWilly
Nov 30, 2002 03:45 PM
