Clunking noise in transmission
I was wondering if anyone had any ideas about what could be causing my transmission to make an awful clucking/ slamming sound when I make a left hand turn? It smaks really loud and sounds like the axle is slipping or something. I dont know what it is. I have a JDM GSR Transmission in my car if that helps. Thanks...
Out of the two, what do you think it would be. I also blew a CV boot tonight....
So you think it may be the cv joint? It is only when I turn. When I am straight the car is fine and nothing makes any noise and both wheels turn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicqm »</TD></TR><TR><TD CLASS="quote">Out of the two, what do you think it would be. I also blew a CV boot tonight....
So you think it may be the cv joint? It is only when I turn. When I am straight the car is fine and nothing makes any noise and both wheels turn. </TD></TR></TABLE>
There's no doubt that if you're boot is torn that the CV joint is wore. Get that axle replaced ASAP, there can be some serious circumstances from a bad CV joint.
So you think it may be the cv joint? It is only when I turn. When I am straight the car is fine and nothing makes any noise and both wheels turn. </TD></TR></TABLE>There's no doubt that if you're boot is torn that the CV joint is wore. Get that axle replaced ASAP, there can be some serious circumstances from a bad CV joint.
Check to see if you CV boot on the axle is torn or ripped. It sounds like an axle going bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicqm »</TD></TR><TR><TD CLASS="quote">What about a set of driveshaft shop axles??? Like the stage one set? I want to build them right....THanks for your help.</TD></TR></TABLE>
Stock axles will be fine if you have a stock or lightly modded swap, no need for aftermarket axles............yet
sutrusu
Jun 16, 2003 01:05 PM
