H22 eg wont go past 2 grand
Old Jan 14, 2004 | 03:07 PM
SAVIOVEGA's Avatar
Default H22 eg wont go past 2 grand
Every time I rev it up, its like it hits rev limiter at 2000 RPM. WTF ?
Old Jan 14, 2004 | 03:26 PM
Maintenance's Avatar
Default Re: H22 eg wont go past 2 grand (SAVIOVEGA)
Sounds like a spark problem. Check yoru coil, ignitor, distributor. Check your wirings again. Check if you got everything wired up correctly. Are you throwing any cel light? If not try reseting your ecu and try reving it up again.
Old Jan 14, 2004 | 08:28 PM
Newman's Avatar
New User
Default Re: H22 eg wont go past 2 grand (racerxfear)
Also, check your grounds. Especially if you're not getting a CEL, then your car is missing and it's an ignition problem. Check the ignitor & coil as well. My NGK plug wires were rubbing against my IC piping at one point and that caused it to arch onto the piping and made the car miss from time to time. Fixed it and the car drove & revved smoothly.
Old Jan 14, 2004 | 10:29 PM
MEANB18's Avatar
Default Re: H22 eg wont go past 2 grand (Newman)
as dumb as it sounds... are you running hondata? if so I would say make sure you don't have a launch control setting thats too low
Old Jan 15, 2004 | 07:13 AM
2trix's Avatar
chk your tps....
bob95egdx
Jan 3, 2012 04:55 PM
ys1civicsi
13
Jan 20, 2010 10:55 AM
slob20ef
Dec 19, 2008 09:01 AM
boosted92hatch
13
Mar 29, 2008 09:34 PM
Rudelude22
Sep 26, 2005 08:03 PM
