ticking noise ?!
Old Jan 14, 2004 | 02:15 PM
tonezilla's Avatar
Default ticking noise ?!
recently while driving my car everytime i make a left turn and aslo hard braking . i hear a loud clicking or ticking noise from the drivers side front wheel . i just want to confirm if this is a cv joint or an axle problem ?! because if it is i would like to get it fixed as soon as possible . also i noticed if i drive my car for awhile i noticed that i start to smell like burnt rubber or plastic from the inside and outside of the drivers side . the scent is not present anywhere else except around this certain area . i checked to see if it was any wires under the dash or plastic bags under the car . can anyone help me ?! its an 94 accord lx . thanks for any replies .
Old Jan 14, 2004 | 02:35 PM
LookingForVTEC's Avatar
Default Re: ticking noise ?! (redxalien)
Sounds like a bad CV joint that is making that noise. Usually a bad CV joint will make a clicking sound when the wheels are turned sharply to the left or right under acceleration. As far as the smell I have no clue.
Old Jan 14, 2004 | 06:23 PM
tonezilla's Avatar
ive read that when u have a problem like this its better to just replace the whole axle . butt i just wanted to know if i should replace it with an oem or aftermarket axle ?!
Old Jan 14, 2004 | 07:34 PM
DrunkNRacer's Avatar
Default Re: (redxalien)
Its definetly a CV gone bad.. take her to a shop or get under that ****** and check for wear
Old Jan 15, 2004 | 02:56 AM
gray_ghost91's Avatar
the smell (if it smeels like burning wires) is your brakes overheating for some reason.... ( i have done this many many many many times) you may need an old fashioned brake bleed
Old Jan 15, 2004 | 12:18 PM
tonezilla's Avatar
would not bleeding your brakes lead to any major problems ?! i am not asking this so i dont have to bleed them . butt its because i have been driving around like this for a week or two and just wanted to know if i caused any major damage to anything .
Old Jan 15, 2004 | 12:34 PM
DBrown's Avatar
yor clicking is probably a CV. there not that hard to do it your self. just have to take the knuckle off, breaks.....blah, blah,.....check out your haynes manual they have a good discription. the burning smell......have you had your oil changed lately? it could be residual from when they took your filter off.
Old Jan 15, 2004 | 01:27 PM
vc's Avatar
vc
Default Re: (DrunkNRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">Its definetly a CV gone bad.. take her to a shop or get under that ****** and check for wear </TD></TR></TABLE>
I concur.. but whats CV mean? LoL
Old Jan 15, 2004 | 02:01 PM
tonezilla's Avatar
i think cv means constant velocity . correct me if i am wrong . and yess i change my own oil every 2-3 months . theres no trace of oil . butt still want to know if there is any major damage caused if you dont bleed your brakes ?! and should i get oem or aftermarket axles ?!
Modified by redxalien at 11:11 PM 1/15/2004
Apple395
May 28, 2015 10:09 AM
ChrisTechMech
Suspension & Brakes
Jul 7, 2014 05:48 PM
lopezchris21
14
Aug 10, 2008 06:57 PM
BLK99VTECR
Nov 10, 2003 01:16 PM
rivvin
Dec 22, 2002 11:44 PM
