help civic b16
Old Jan 14, 2004 | 01:24 PM
chulopilong's Avatar
Default help civic b16
i have a civic hatch 93 with a b16. my car seems to stall. it doesnt turn of mut it kind of bogs. it flashes a code. manifold pressure sensor(ithink, im not positive if the first flash is an indicator) if it is an indicator that i believe the code represents ox sensor 2. witch one is it. and what is it help. thank new
Old Jan 14, 2004 | 01:51 PM
TeamNextGenChris's Avatar
Default Re: help civic b16 (chulopilong)
first you need to figure out exactly which code you have before we can help you.use the search function to find out how to properly read the codes on your car.
chris
Old Jan 14, 2004 | 01:57 PM
Default Re: help civic b16 (TeamNextGenChris)
it code 3 manifold absolute pressure sensor.
JDMlyfestyle's Avatar
click the check your ecu codes in my sig. gives you the process how to check the codes. And then search through the list for your code # good luck
Old Jan 14, 2004 | 02:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chulopilong &raquo;</TD></TR><TR><TD CLASS="quote">it code 3 manifold absolute pressure sensor.
a MAP problem can definately cause the symptoms you're speaking of...go here
http://www.icelord.net/honda/repair/and DL the 92-95 manual(same procedure for the B16)and do the troubleshooting procedure for the MAP sensor circuit.if you need help,let me know.
chris
bmoua
Dec 29, 2007 09:08 PM
mygfs92lx
Jul 21, 2006 08:00 PM
gsrturbo-ek
Apr 19, 2006 07:31 PM
civicx
Oct 4, 2005 03:12 PM
gsr2envy
Nov 7, 2004 03:32 PM
