v-tec on accord 5 spd
ok i did a search on this and came up empty handed but i was wondering when the v-tec really kicks in. i cant hear it nor feel it in my car and i have heard debates saying it kicks in at 3200 and also that it kicks at 4000? does anyone really know?
on the sohc vtec accord... the vtec engagement is not fixed and is somewhat variable. depending on the sensors output to the computer and the engine load it can kick into vtec from as low as like 2200 and as high as 3200 (on my 95 I have observed the sensor output real time to confirm).
btw this is all in reference to my 95 sohc vtec.
edit: confirmed the sensor readings I get from my vafc agian with a friend who has a 94 ex auto with only an intake/ exhaust and vafc. we both get the same results.
Modified by twkdCD595 at 2:31 AM 1/16/2004
alright so how do i tell for sure where my v-tec kicks in my 94? do i have to have it dyno'ed to know that or is there a simpler way?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">its VTEC</TD></TR></TABLE>
Lol....I dont know if everyone really knows what VTEC stands for......is it Valuable or maybe Vertical...........oh yeah, VARIABLE.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">ok now that we have determined that can you give me the answer of how i know when my VTEC kicks??? </TD></TR></TABLE>
You dont know when it is going to kick. Oil temperature, Oil pressure, engine speed, and I think even water temperature all create variables for when the secondondary lobes are activated.
Here is a get smart link that everyone who is confused about it should read....
http://auto.howstuffworks.com/question229.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jagged4698 »</TD></TR><TR><TD CLASS="quote">alright so how do i tell for sure where my v-tec kicks in my 94? do i have to have it dyno'ed to know that or is there a simpler way?</TD></TR></TABLE>
I use my vafc...
although some people still tell me to disconnect the vtec portion cause the ecu engages it lower than I can control... I still run it fully functional.
edit: my spelling sucks sorry.
Modified by twkdCD595 at 5:01 PM 1/14/2004
I use my vafc...
i was just gonna say to get one of the vtec engagement lights....but i never new preludes had them, are they stock???...i think thats kinda cool....and are they a bitch to install????
Guest
Posts: n/a
VTEC light i got a lude and i have no clue what your talking about. and for you question VTEC comes on when the cars going 13 mph or faster, more than 30% throttle. i pretty sure it stays in the same spot , atleast the h22 does, its set for the best performance on that cam profile for your stock motor, but when you start modding, your power curve changes, thats why you tune it on the dyno, well atleast VTEC timing, you run the low cam then the high cam and where they make a X is where you put it at!! get it
damn thats one long *** sentence
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jagged4698 »</TD></TR><TR><TD CLASS="quote">ok i did a search on this and came up empty handed but i was wondering when the v-tec really kicks in. i cant hear it nor feel it in my car and i have heard debates saying it kicks in at 3200 and also that it kicks at 4000? does anyone really know?</TD></TR></TABLE>
What do you have done to your car..?? You probalby can't tell if its just stock.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">the h22 has a fixed engagement point (unless you have a vtec controler or whatnot).
the f22b1 does not.
</TD></TR></TABLE> well sorry my bad i was just saying thats how mine was, thats weird with the f22b1
the f22b1 does not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiNeFouRCorD »</TD></TR><TR><TD CLASS="quote">
What do you have done to your car..?? You probalby can't tell if its just stock.</TD></TR></TABLE>
Well all i have that would effect any of that is a CAI....i dont know if that is helpful or not? Also reffering back to the lights in preludes do you think they make those for all model cars or just for the preludes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSi93 »</TD></TR><TR><TD CLASS="quote">I just drove a '94 Accord EX Coupe and I could hear it hit at 5500 every time except before it warmed up, seemed pretty regular to me as long as I was flooring it</TD></TR></TABLE>
watch the ecu output signal to the silinoid with a vtec indicator light, voltmeter, vafc, etc for more solid info than "I could hear it hit at...".
btw edited my above first post to reflect the proper rpm range I observed.
Modified by twkdCD595 at 2:34 AM 1/16/2004
It constantly hit at a fixed point cus you floored it...it engages differently based on how much your pressing the pedal/ accelerating...also i don't think it would engage that high
There is no set RPM at which Vtec kicks in. A variety of different things determine when it will kick in. For my Accord it is suppose to kick in at 4200rpms which is about average.
just FYI:
VTEC stand for: Variable valve-timing and Electronic lift Control
and what type of meter are you guys using to monitor the voltage at the VTEC solenoid on the F22B1?
FastechAccord
Feb 3, 2002 11:25 AM
