Need help with V-AFC on SOHC VTEC Accord
did any one else with a V-AFC have problems with their vtec engagment point?? Mine is acting real weird and I need some help.
New User
Re: Need help with V-AFC on SOHC VTEC Accord (4doorH22)
make sure your connection is good as well b/c the V-AFC will get real unless the connection is soddered well...
Re: Need help with V-AFC on SOHC VTEC Accord (EvoAccord)
I figured out the problem, the vtec on my SOHC VTEC 2.2 kicks in at 2500 from the factory. I was under the impression the vtec kicked in at 5500 by the sound of the engine at that rpm. I couldnt figure out why the car ran so slow when the vtec engagment point was changed to 4000 rpms. So, anyone with a F22B vtec, you vtec kicks in at 2500.....extremely early, but if you have it kick in later, it runs like crap.
New User
Re: Need help with V-AFC on SOHC VTEC Accord (wizurdofawwz)
set it at 3500... i have the dyno charts to prove it's the best x-over... even Misa will agree...
Yes.
I can confirm that the engagement point is indeed at 2500rpm. You can verify that by hooking up an led to the VTM wire of the ECU.
So that's why our F22B1 is not listed on the compatibility list on the VAFC page. We're supposed to use the SAFC...
Re: Need help with V-AFC on SOHC VTEC Accord (Mark27)
Yes.
EDIT: wait a minuite you cant set it lower than 3k rpms anyway , Whats going on here?
[Modified by SOHCkordVTEC, 7:15 AM 2/1/2002]
Re: Need help with V-AFC on SOHC VTEC Accord (DunReit)
There is no VTEC with a SOHC f series until 4200rpms or so. 2500? not enough oil pressure like Misa said.
Re: Need help with V-AFC on SOHC VTEC Accord (Hondasport94)
I can verify this. Not a good way to have found out....but I did anyhow. A couple of weeks ago my car was extremely low on oil. So, when I would take a corner fast, flooring it....my car would go slow...then around 4000 VTEC would kick in rather hard, kind of like an automatic, it was weird. And YES I know it was stupid of me to be driving like that with low oil.
no 4k is to high, you want to set the x-over at the point where the low and hicam will make the same power so there is no jerking. mine was set at 3500 before my car got broken into and stolen
='( i miss my vtec
='( i miss my vtec
Re: Need help with V-AFC on SOHC VTEC Accord (SOHCkordVTEC)
The cutover point varies based on input from several sensors. If you have a factory manual (Helms) for the 97 Accord check out page 5-7.
Anywhere between 2300 and 3200 rpm depending on intake manifold pressure. Also depends on engine speed and coolant temp.
The ECM monitors the sensor inputs and kicks in the VTEC.
:bows:
Here's a pretty informative site all about VTEC and how it works if anyone wants to take a look at it who hasn't. http://www.leecao.com/honda/vtec/index.html
:bows:
Great site I've had it bookmarked for awhile now and have read most of it.
Banned
Yes Mark27, I also have an LED connected to the Vtec solenoid positive feed and it does kick in somewhere around 2500 if gassed hard, if foot lightly on gas it will kick in somewhere around 3000... I always thought my car was weird for having vtec kick in that early.. now does this apply to all sohc vtec accords or just certain ones?
Banned
while mark tapped into the ecu, my wire ran through the firewall and tapped into the vtec solenoid, which is 5" cylinder next tothe valve cover. the green wire running into/out of it is positive and charges with 12v whenever vtec kicks in... at least that's what i've been informed by several websites... the other end i grounded the led and placed it in the dash cluster, but that's another story...
DunReit, do you have any dynos you can post so I can see that i definately want to set my vtec up to 3500. If i move it up the car lacks alot of power down low. If I run my car thru autocross or any hairpin turns i would have trouble coming out of the turn if my RPMs dropped below 3500.
I don't know if the signal change of the VTM wire at 2500rpm is the vtec engagement point. Because according to various manuals, it's supposed to be until 4000rpm
DunReit:
How can a dyno chart shows when vtec engages in sohc vtec engines? A sudden increase in horsepower doesn't mean there is a switch of cam profile. The engagement point is defined by a signal that's supposed to change in the VTM wire.
wizurdofawwz:
blue led from radio shack, then calculate the resistors you need to use, hook the negative side of the led in series with the resistors, then to the ground. The positive side of the led to the VTM signal wire.
I did it just for fun. I permananently hooked it up to illuminate my power window buttons now
DunReit:
wizurdofawwz:
New User
if you compare where you set the VTEC xover on different dyno runs, you can see a huge difference... this comes from my experience with three different dyno tuning sessions over the past 2.5 years...
i'll post my dyno charts as soon as i can find a scanner to scan them in (my scanner broke)...
