ls vtec ? :: gsr rod bearing on ls rod? ::
could someone tell me if i can use ACL b18b1 main bearings, and ACL b18c rod bearings on ls rods? what is the advantage over the ls rod bearing?
If you gonna run an ls crank adn rods then stick with all ls bearings. That way you dont have any problems. I actually think the crank journals are different sizes so i dont even know if it would work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 »</TD></TR><TR><TD CLASS="quote">could someone tell me if i can use ACL b18b1 main bearings, and ACL b18c rod bearings on ls rods? what is the advantage over the ls rod bearing?
to run gsr bearings on ls rods you need to notch the rods to make them fit right.
Not worth since acl's are the same quality for all b-series.
stock gsr rod bearings are a little better since they have a coating on them.....still think not worth it...
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
wacktical
Jul 20, 2005 01:44 PM
