Greddy kit on a B18c in an EG coupe. need new 3" DP
Old Jan 14, 2004 | 09:10 AM
madman604's Avatar
Default Greddy kit on a B18c in an EG coupe. need new 3" DP
okay, here's my problem. I need a 3" Dp for my greddy turbo. I'm using a Greddy kit, which is designed for a Teg body/exhaust.
I have shortened the greddy DP to fit my Civic exhaust
I was using a B16A exh manifold befor the turbo and it fit perfectly w/ civic exhaust.
So..where can i get a 3" DP that is basicly the same length as the DP onGreddy kit for the B16a
or am I stuck looking for a custom job locally?
does this make sense?
Old Jan 14, 2004 | 10:22 AM
The Shodan's Avatar
custom.
Old Jan 14, 2004 | 10:57 AM
horror's Avatar
Default Re: (The Shodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Shodan &raquo;</TD></TR><TR><TD CLASS="quote">custom.</TD></TR></TABLE>
yea your are pretty much going to have to go custom, ive been looking and nobody seems to make a larger dp for any of the honda greddy kit.
Old Jan 14, 2004 | 11:21 AM
dfoxengr's Avatar
Default Re: (horror)
itd probly be even cheaper to get someone to weld you one locally anyways.
Old Jan 14, 2004 | 11:52 AM
madman604's Avatar
so i should just redo the section of piping, from (after)the Cast greddy elbow to the CAT?
Old Jan 14, 2004 | 12:51 PM
horror's Avatar
Default Re: (Turbo E)
you can do that and flare it out if you are worried about clearance issues up front, if not than go with a full 3"
Old Jan 14, 2004 | 01:46 PM
ProEater's Avatar
ive been searching forever and custom is the only way
motive
Oct 17, 2008 09:54 PM
B16Civic93
Apr 10, 2005 03:37 PM
1NasteeEp
Apr 20, 2004 01:28 PM
VTpreludeVT
Oct 10, 2003 08:38 AM
mod5
Mar 31, 2002 09:22 PM
