Light Weight Flywheel??
Old Jan 14, 2004 | 08:40 AM
romeirome1's Avatar
Default Light Weight Flywheel??
is a light weight fly wheel a really good thing to have or is it over rated. and what advantages does one have over a regular one.
Old Jan 14, 2004 | 08:56 AM
8200RPM's Avatar
local hippie
Default Re: Light Weight Flywheel?? (romeirome1)
lightened flywheel will rev faster
Old Jan 14, 2004 | 11:01 AM
horror's Avatar
Default Re: Light Weight Flywheel?? (8200RPM)
a lightweight flywheel also makes it alot easier to match revs and i think it just makes the car more fun to whip around.
Old Jan 14, 2004 | 11:09 AM
doublejz's Avatar
Default Re: Light Weight Flywheel?? (horror)
search my friend, there are alot of mixed feelings about them, lighter = rev higher to start, u don't have the mass to keep you going as well as a heavier one (inertia)I couldn't decide so I kept with stock
Old Jan 14, 2004 | 12:22 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romeirome1 &raquo;</TD></TR><TR><TD CLASS="quote">is a light weight fly wheel a really good thing to have or is it over rated. and what advantages does one have over a regular one.</TD></TR></TABLE>
A lightened flywheel is an excellent 'bang for your buck' upgrade.
Your acceleration from zero rpm onwards will totally be enhanced with snappy throttle response. There's a variety of lightened flywheels such as the billet aluminum type or having your stock f.wheel shaved down at a local machine shop which differ in pricing.
From personal experience tho, you'll probably wanna try a 10-13lb flywheel. It's an upgrade you can totally feel and notice as soon as you start driving.
Old Jan 14, 2004 | 02:55 PM
rapid_roy's Avatar
Not over rated, and well worth the money. No drawbacks that I have found in 20k miles since I got mine (8.8lb).
Cheers,
Sean
Old Jan 14, 2004 | 02:57 PM
Kendall's Avatar
Not to mention the fact that a lighter flywheel will save you a few pounds off the total vehicle weight, which is always good.
Old Jan 14, 2004 | 09:38 PM
Zatar69's Avatar
Default Re: (Kendall)
You could always go with a Type-R flywheel. They weigh in at about 14lbs vs 18lbs for the GSR... I think.
Someone correct me if I'm wrong.
Old Jan 14, 2004 | 10:18 PM
blackeg's Avatar
Default Re: (Zatar69)
it a good thing...except possibly for turbo applications, cause it makes your revs drop faster while shifting and can make you go back out of boost. i got a 12lb one and i think its perfect
Old Jan 15, 2004 | 06:09 AM
EE_Chris's Avatar
Default Re: (blackeg)
Going with too light a flywheel can, and has been shown, to cause idling problems. A heavier flywheel has more mass and thus more energy to keep things rotating than a lighter part.
Only a heads-up, not trying to sway you from it as I agree with whats been said.
Old Jan 15, 2004 | 06:18 AM
ExVtec's Avatar
if you plan on being boosted, not an upgrade one should think about?
I will have to be replacing my cluctch soon, so I thought I would take it into consideration...
Old Jan 15, 2004 | 10:18 AM
senpai's Avatar
Default ...
That's all hearsay. I have 7.5lb flywheel with ACT XTSS. The idle is stock and to be quite honest; I didn't even 'feel' a difference. Technically, there is a difference, but I couldn't feel ****.
Apexi turboed D16
Old Jan 15, 2004 | 10:23 AM
benSC's Avatar
I have an ITR flywheel in my B16, and it's awesome. It's perfect for street driving, not too light.
Old Jan 15, 2004 | 01:49 PM
ultimatehonda's Avatar
I have a light weight fly in my Si. Its a ACT prolite... You can feel the diff with that fly and it will rev up quicker. I picked the ACT because it was cromolly and I basicly use it on the street with the exception of a few strip runs and did not need anything lighter. There are a lil bit lighter flywheels, some are made of aluminum and some of cromolly. There is speculation about aluminum flys being bad but i doubt it. Just remember lighter is not always better. Pick something for your application. Boosted cars will requier a lil bit heavier flywheel because of the more power output. Also a really light flywheel will be a lil bit harder to take off cause you need to rev the car up more to build up the inertia.
Old Jan 15, 2004 | 02:55 PM
ForceThis!'s Avatar
I stuck with the OEM 19# monster on my TC'd F. The whole aluminum thing scared me and I couldn't find a lightened steel unit for my app. Oh well.
Cyrio
62
Aug 14, 2006 05:11 AM
dornon13
Oct 18, 2005 07:23 AM
yellowturbo
Dec 20, 2004 08:59 PM
freezerburnv2
Feb 25, 2004 11:49 AM
zseeanz
26
Jan 16, 2004 12:10 AM
