custom spring rate fast question!!!
Old Jan 14, 2004 | 01:10 AM
BoOsTiN Dc2's Avatar
Default custom spring rate fast question!!!
this is for a daily street/ track 1/4 mile driven car.... i have a integra and i was thinking about getting spring rate of 500/400 lbs give or take and i notice stock usually the front is stiffer, but i also see people using the stiffer springs in the back... i wanted to know whats the pros and cons of having stiff spring in the front and soft in the back and vice versa
Old Jan 14, 2004 | 06:29 AM
rapid_roy's Avatar
Default Re: custom spring rate fast question!!! (tRaCeBuStAbUsTeR)
That is an autox/track setup. The higher spring reate sin the rear allow you to rotate the rear end around while entering a corner. Not very useful for a drag or a street car.
Cheers,
Sean
Old Jan 14, 2004 | 07:29 AM
azian21485's Avatar
you'll want stiffer springs in the back than the front for 1/4 also..it'll help you get traction to the front wheels by keeping them on the ground during weight transfer...
twilightprotege
Suspension & Brakes
Jan 17, 2006 01:07 PM
bad-monkey
Aug 24, 2004 05:24 PM
Dyzee
May 1, 2004 05:35 PM
ActiveAero
Oct 4, 2002 08:22 AM
Muckman
19
Aug 9, 2002 12:00 PM
