anyone turbo a f22a ?
build it yerself or buy a kit, either way, as long as you manage it properly, you can run a safe 7# (could be any spring, the # is up to you) all day for years. A good freind boosted his stock Fa at the same time I did my Fb, almost 2 yrs ago, and has had zero problems, and he had 163k on it when he did it, stock head gasket even. yes, it was a daily driver, and he was putting down roughly 188whp/172#tq
f23? i was wondering about f22a non vtec sohc
anyone know of a good place to get parts to built a turbo kit for a f22a somewhat inexpensively?
get a list of everythign you need and start looking around
you can find a ton of it in the classifieds and others through shops
some stuff you want to go used and others new!!
dont go cheap on some stuff, youll regreat it.. if it can blow your **** up easy.. get it new or close to it
-hardware
turbo
intercooler
downpipe w/ o2 bung
exhaust mani
bov
waste gate
gaskets
intercooler piping
silicone connectors
map sensor bypass
hi flow fuel pump
injectors
colder spark plugs
boost gauge
a/f gauge
oil feed line
fuel pressure regulator
fuel pressure guage
oil return line
fitting for oil pan
silicone lines for vaccum
SS clamps
zip ties
-software/management
hondata>aem ems>apexi vafc/safc
-prep work/tuning
dyno runs
compression test
leakdown test
turbo
intercooler
downpipe w/ o2 bung
exhaust mani
bov
waste gate
gaskets
intercooler piping
silicone connectors
map sensor bypass
hi flow fuel pump
injectors
colder spark plugs
boost gauge
a/f gauge
oil feed line
fuel pressure guage
oil return line
fitting for oil pan
SS clamps
zip ties
-prep work/tuning
dyno runs
compression test
leakdown test
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">-hardware
turbo
intercooler
downpipe w/ o2 bung
exhaust mani
bov
waste gate
gaskets
intercooler piping
silicone connectors
map sensor bypass
hi flow fuel pump
injectors
colder spark plugs
boost gauge
a/f gauge
oil feed line
fuel pressure guage
oil return line
fitting for oil pan
SS clamps
zip ties
-prep work/tuning
dyno runs
compression test
leakdown test
excellent shopping list
turbo
intercooler
downpipe w/ o2 bung
exhaust mani
bov
waste gate
gaskets
intercooler piping
silicone connectors
map sensor bypass
hi flow fuel pump
injectors
colder spark plugs
boost gauge
a/f gauge
oil feed line
fuel pressure guage
oil return line
fitting for oil pan
SS clamps
zip ties
-prep work/tuning
dyno runs
compression test
leakdown test
