Valve Overlap
Old Jan 13, 2004 | 04:08 PM
pip9's Avatar
Default Valve Overlap
Can someone explain to me why modern engines use valve overlap as opposed to haveing the intake and exhaust valves opened seperately?
Old Jan 13, 2004 | 04:41 PM
Kendall's Avatar
So that when the intake valves are opened, the air will not only have atmospheric pressure pushing it in, but momentum from the air being blown out of the exhaust valve. This results in more airflow into the combustion chamber which equates to more power.
Old Jan 13, 2004 | 08:01 PM
Mohudsolo's Avatar
Default Re: (Kendall)
It's not just modern engines. Any race motor or old 60's muscle car with a "lope" or rumpa rumpa at idle has a bunch of overlap. Larger amounts of overlap will generally give more power on the top end with some loss on the bottom end. Very little or no overlap will give great bottom end but will go flat real early. A good example is the GM TPI motors from 85-90ish Vettes. Great power right from idle, but dead by 4500. Some of that is also the intake design, but they were made to work together.
97G_TechLX
Aug 14, 2011 02:07 PM
LastGenEK
Apr 3, 2008 11:09 PM
Mover
Jul 26, 2002 02:53 PM
kidkutz
Jun 5, 2002 09:05 PM
