How good are oversized valves?
Old Jun 5, 2002 | 01:37 PM
kidkutz's Avatar
Default How good are oversized valves?
Was thinking of using 0.5mm over valves...is it worth the machine work to put them in?
Old Jun 5, 2002 | 01:46 PM
PrecisionH23a's Avatar
Default Re: How good are oversized valves? (kidkutz)
i was told that on a turbocharged application you will compensate your lower end power but gain a little bit of top end power from the o.s. valves. On my h23a i was told it would not be that benificial, but o.s. valves have to do something... feel free to post some info on this topic, im curious about the exact pro's and con's of having os valves are
Old Jun 5, 2002 | 02:21 PM
2K_TEG's Avatar
Default Re: How good are oversized valves? (GudeH23a)
In some situations an oversized valve actually hurts performance -- Joe Alaniz.
Old Jun 5, 2002 | 02:23 PM
93LSivic's Avatar
From what Ive heard on the LS motors is that only .5 oversize on the exhaust valves seem to be good. Stock on the intake. But this is just what I heard, and Im sure H motors might be different.
Old Jun 5, 2002 | 02:24 PM
RCSIVTEC's Avatar
i would go with a 1mm oversized but you have to use the right combination for the intake and exhaust. remmber if you have alot of air comming in you also have to have a lot of exhaust comming out to.
Old Jun 5, 2002 | 04:11 PM
kidkutz's Avatar
Default Re: How good are oversized valves? (RCSIVTEC)
why would you go 1mm over?
so what you're saying is if you go 1mm over on the intake...go one over on the exhaust as well right?
Old Jun 5, 2002 | 08:40 PM
RCSIVTEC's Avatar
i would personally go 34mm intake and 29 mm exhaust thats if you running on a vtec head. that should give you all the flow that you will ever need. use ferrea superflow valves a bit more expensive but you get what you pay for.
Old Jun 5, 2002 | 09:00 PM
trbob16a's Avatar
This may be a dumb question, but are there any issues with running larger valves and having them not fit into the valve cut outs on the piston? I haven't measured mine because the block is 1200 miles away, but I was thinking about claying the motor just to be safe. I have 1mm over with arias 9:1.
Old Jun 5, 2002 | 09:05 PM
RCSIVTEC's Avatar
Default Re: How good are oversized valves? (trbob16a)
i only assume when you are running larger valves you have to take into account the valve size cut on the pistion. everything has to measure extaclly so it can work in harmony
namewasdallas
15
Apr 30, 2011 04:14 AM
lude98SH
21
Dec 13, 2006 01:36 PM
breathinez
Aug 24, 2004 10:35 AM
airborne84000
Jan 8, 2003 04:11 AM
vwandhondaboy
Sep 29, 2002 12:08 PM
