to lean????
right about 7200 RPm in forth gear i notic that the car doesn't pull all the way the redline, as fast as in 1st-3rd. could this mean i'm running to lean???
i think my TP may be bad too, could that have something to do with it??? thanx
let me try to reword this...
at around 7200 RPM the car seems to sputer... and i do notice this in 3rd as well.
it's just not as bad.
now i know i'm doing around 115 MPh in foruth so running out of hourse power to push the car could be the problem, but it doesn't "feel" like it's running out of power. when i shift to 5th the power is there untill 120 MPh when the speed limter hits. any help??
its a stock 95 h22 with i/h/e upgraded fuel pump to a holy that flows 255lph
stock injectors, and no fpr.
and for the tp. at around 3000 RPM it has a dead spot, it just feels like it isn't making any power, but if you floor the gas the dead spot goes away, and you have power again.......
[Modified by cccya, 8:22 PM 9/29/2001]
Drew96EJ
Apr 25, 2005 08:07 PM
Broken Devil
Jul 31, 2004 02:05 PM
