to lean????
Old Sep 29, 2001 | 09:13 AM
cccya's Avatar
Default to lean????
right about 7200 RPm in forth gear i notic that the car doesn't pull all the way the redline, as fast as in 1st-3rd. could this mean i'm running to lean???
i think my TP may be bad too, could that have something to do with it??? thanx
Old Sep 29, 2001 | 09:52 AM
rioninja's Avatar
Default Re: to lean???? (cccya)
I gotta ask, is this your first car?
Old Sep 29, 2001 | 10:57 AM
cccya's Avatar
Default Re: to lean???? (RioNinja)
let me try to reword this...
at around 7200 RPM the car seems to sputer... and i do notice this in 3rd as well.
it's just not as bad.
now i know i'm doing around 115 MPh in foruth so running out of hourse power to push the car could be the problem, but it doesn't "feel" like it's running out of power. when i shift to 5th the power is there untill 120 MPh when the speed limter hits. any help??
Old Sep 29, 2001 | 11:08 AM
rioninja's Avatar
Whats your setup? is this a stock motor?
As for the TPS, what makes you think it is bad?
Please post some more info on your setup.
Old Sep 29, 2001 | 11:18 AM
cccya's Avatar
its a stock 95 h22 with i/h/e upgraded fuel pump to a holy that flows 255lph
stock injectors, and no fpr.
and for the tp. at around 3000 RPM it has a dead spot, it just feels like it isn't making any power, but if you floor the gas the dead spot goes away, and you have power again.......
[Modified by cccya, 8:22 PM 9/29/2001]
souchiem
10
Jun 18, 2013 06:13 AM
Slick-Prelude487
Feb 22, 2008 10:26 AM
Drew96EJ
Apr 25, 2005 08:07 PM
Broken Devil
Jul 31, 2004 02:05 PM
