wondering about 5 lug conversion
Old Jan 13, 2004 | 08:38 AM
temp's Avatar
Default wondering about 5 lug conversion
is this just as simple as swapping the knuckles and spindles from an ITR and the RTAs from the type r as well or must something special be done? how about the ABS calipers? will they be affected if there is no ABS system on the car?
Old Jan 13, 2004 | 08:40 AM
EL Vap133's Avatar
Default Re: wondering about 5 lug conversion (temp)
I don't think you want to use the ITR knuckles, you have an EF right?
Old Jan 13, 2004 | 08:41 AM
temp's Avatar
Default Re: wondering about 5 lug conversion (EL Vap133)
no i have an ED just like you , why not? are they the same length as the 90-93 integra knuckles?
Old Jan 13, 2004 | 08:43 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">no i have an ED just like you , why not? are they the same length as the 90-93 integra knuckles?</TD></TR></TABLE>
I doubt they are, even if they are I believe the curviture on the knuckle is much different than DA or 90-91 EX Civic Sedan knuckles. That means your alignment will be very fuct...
Old Jan 13, 2004 | 08:44 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
I doubt they are, even if they are I believe the curviture on the knuckle is much different than DA or 90-91 EX Civic Sedan knuckles. That means your alignment will be very fuct...</TD></TR></TABLE>
wrong, i have DA knuckles on my car now with no camber or caster problems, using the DA A-arm is when you get problems ......so can you answer the question about the 5 lug conversion?
Old Jan 13, 2004 | 08:50 AM
EL Vap133's Avatar
wrong, i have DA knuckles on my car now with no camber or caster problems, using the DA A-arm is when you get problems ......so can you answer the question about the 5 lug conversion?</TD></TR></TABLE>
Did I say that using DA knuckles were bad? Please learn how to read...
Old Jan 13, 2004 | 08:53 AM
temp's Avatar
Did I say that using DA knuckles were bad? Please learn how to read... </TD></TR></TABLE>
damn damn damn, hey do have a link to the thread with the 89 hatch where the guy did an entire ITR change over? he used the ITR knuckles if i remember right and had no issues with them, i will find it (if you dont) and IM him
Old Jan 13, 2004 | 08:59 AM
EL Vap133's Avatar
damn damn damn, hey do have a link to the thread with the 89 hatch where the guy did an entire ITR change over? he used the ITR knuckles if i remember right and had no issues with them, i will find it (if you dont) and IM him</TD></TR></TABLE>
yeah, see what he did to make it work...
Old Jan 13, 2004 | 09:10 AM
temp's Avatar
yeah, see what he did to make it work...</TD></TR></TABLE>
well i sent him an IM and i am waiting for a reply he is not online now
Old Jan 13, 2004 | 12:51 PM
EL Vap133's Avatar
well i sent him an IM and i am waiting for a reply he is not online now</TD></TR></TABLE>
cool....
Old Jan 13, 2004 | 01:06 PM
temp's Avatar
Old Jan 13, 2004 | 01:50 PM
bryant's Avatar
I knew these pics would come in handy some day:
Left 90-91 EX knuckle. Right DC2/EG knuckle
You can use EG/DC2 just fine. you will just need a camber kit most likely and for sure an alignment. Bolt up thte five lug and get some longer ebrake cables and your set. Done deal.
Old Jan 14, 2004 | 06:44 AM
temp's Avatar
Default Re: wondering about 5 lug conversion (Bryant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryant &raquo;</TD></TR><TR><TD CLASS="quote">I knew these pics would come in handy some day:
You can use EG/DC2 just fine. you will just need a camber kit most likely and for sure an alignment. Bolt up thte five lug and get some longer ebrake cables and your set. Done deal.</TD></TR></TABLE>
and the ITR RTA's are bolt on? what about ABS calipers in a NON-ABS system? would the calipers be affected at all?
Old Jan 14, 2004 | 06:50 AM
hondahans's Avatar
I use DA - GS ABS calipers on mine. I have no problems with them.
Old Jan 14, 2004 | 07:18 AM
1's Avatar
Default Re: wondering about 5 lug conversion (hondahans)
Why do people insist on quoting people and including the pics again? Sorry, this is annoying as hell.
Old Jan 14, 2004 | 07:52 AM
EL Vap133's Avatar
Damn Bryant, after looking at your pics I would be scared to use the DC,EG knuckles in my crx....
Old Jan 14, 2004 | 08:47 AM
kid-honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Damn Bryant, after looking at your pics I would be scared to use the DC,EG knuckles in my crx.... </TD></TR></TABLE>
Yea No ****!
With a camber kit fully maxed out the wheels might be straight but if you lower it at all I bet you would get some narly camber.
Old Jan 14, 2004 | 11:40 AM
primoEF's Avatar
Default Re: wondering about 5 lug conversion (kid-honda)
if you use DC kunckle you will get almost 0 camber or even + camber, thats no good for driving, thats why I swaped out the DC for DA kunckles and I end up with -2.5 cabmer which is good for me since I drive the car mostly on the track, if the toe is good then it won't eat up tires
Old Jan 14, 2004 | 02:19 PM
temp's Avatar
can the ITR hubs be swapped onto DA knuckles?
Old Jan 14, 2004 | 03:12 PM
bryant's Avatar
Default Re: (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">can the ITR hubs be swapped onto DA knuckles?</TD></TR></TABLE>
Yes. But its not just simple press in.
Old Jan 15, 2004 | 07:12 AM
temp's Avatar
Default Re: (Bryant)
can you elaborate?
Old Mar 29, 2004 | 09:40 PM
iNetForce's Avatar
Default Re: (temp)
I have a 88 crx dx, would the itr knukle fit by just pressing in?
OmarR
Jul 23, 2013 10:42 AM
OmarR
Jul 22, 2013 11:28 PM
EricUSC
21
Apr 18, 2009 05:40 PM
MenaceL.A.671
Apr 6, 2008 12:40 AM
MenaceL.A.671
Apr 1, 2008 10:08 PM
