Fuel Pressure
Old Jan 13, 2004 | 07:09 AM
Z6REX-SI's Avatar
Default Fuel Pressure
I have a 88 CRX-SI with a z6 motor and RC injectors, AEM Fuel pressure reg., walboro ext. pump, and B&M gauge. My injectors are 270cc and I don't have a cat. on the car other than that the car is stock. My question is what psi should I have my fuel set and do I check the fuel pressure with the hose attached or unattached. Thanks in advance.
Old Jan 13, 2004 | 10:01 AM
Z6REX-SI's Avatar
Default Re: Fuel Pressure (Z6REX-SI)
I know a lot of you guys out that have adjustable fuel pressure regulators. If you can just tell me if the hose should be connected or disconnected when determining fuel pressure I would greatly appreciate it. Thanks.
Old Jan 13, 2004 | 10:33 AM
91civicEX's Avatar
i think it should be disconnected since that simulates fuel pressure at WOT. just usin common sense so i might be wrong.
Old Jan 13, 2004 | 10:59 AM
SOHCEK-Turbo's Avatar
Default Re: Fuel Pressure (91civicLX)
I did it with the hose connected and it worked out great.
Old Jan 13, 2004 | 11:13 AM
raene's Avatar
I set pressure with the car off by priming the pump and then looking at the gauge. Seems to work for me... I don't touch the hose. I might be wrong in my technique though, but who cares, as long as my tune is built around the fuel pressure I have no reason to modify it.
si90rex
15
May 18, 2010 05:03 PM
808cuban
Feb 14, 2008 07:24 PM
Mr.EM1
Jan 6, 2005 11:17 AM
BoOsTiN Dc2
Aug 23, 2004 01:16 PM
