Help, valve breather
Old Sep 29, 2001 | 05:23 AM
Sedat1ve's Avatar
New User
Default Help, valve breather
I bought a valve breather (small filter for vavle cover) with my intake. On my 96 Accord there are two inlets on the valve cover. One connects directly into the throttle body and one connects into the intake pipe. Which inlet do I put the little valve breather on?
Old Sep 29, 2001 | 10:03 AM
4doorH22's Avatar
Default Re: Help, valve breather (Sedat1ve)
Ummm if I recall correctly, neither. Both of those lines (PCV and EGR) rely on the vacuum coming from your intake/TB.
Old Sep 29, 2001 | 10:11 AM
Sedat1ve's Avatar
New User
Default Re: Help, valve breather (4doorH22)
Than where the hell does this valve breather go??
Old Sep 29, 2001 | 12:13 PM
SOHCArchangel's Avatar
on the valve breather port in the upper right hand corner of the valve cover of course
Old Sep 29, 2001 | 01:09 PM
Sedat1ve's Avatar
New User
Default Re: Help, valve breather (SOHCkordVTEC)
OK that's what I did but if you're looking at the car the port is on your left. Thanks.
Old Sep 30, 2001 | 09:35 AM
John's Avatar
New User
If your state requires emissions testing on a regular basis, be sure to remove the valve breather before your test. They will fail you.
erikiksaz1
Engine Management and Tuning
Sep 25, 2011 09:37 PM
honda95civic
Feb 5, 2005 01:41 PM
spencer00si
Sep 6, 2002 01:46 PM
Ri5e
Aug 11, 2002 03:28 PM
fiebru1119
Feb 19, 2002 05:34 AM
