What is wrong with my turbo? leaking oil? need help.
Old Jan 12, 2004 | 11:48 PM
tslag's Avatar
Default What is wrong with my turbo? leaking oil? need help.
I changed my oil 5 days ago. Since then my car has had a weird oil smell while running. I used 4.25 of mobil 1 like always. My comp is good and my oil looks fine. I noticed this on my turbo today. I have never noticed this before. Sorry for the blurry pic.
At first I thought I added too much oil but I checked and it looks fine. Would the smell be from the oil burning off the turbo? Why is the oil leaking. I have 15K miles on the turbo and it is a drag III kit. I still get boost like normal. Running 11 psi.
Thanks any help is appreciated.
Old Jan 12, 2004 | 11:52 PM
Kwuaymaikrup's Avatar
Default Re: What is wrong with my turbo? leaking oil? need help. (tslag)
Looks to me like the seals are blown. Pull the charge pipe of of the compressor housing and check for oil there. If you find any it might be time for that bigger turbo you have been wanting
-Ryan
Old Jan 13, 2004 | 02:03 AM
junior69's Avatar
Default Re: What is wrong with my turbo? leaking oil? need help. (Kwuaymaikrup)
yeah looks like your oil seals in the turbo have failed or are failing gradually,have you noticed any clouds of blue smoke out your exhaust when running,the same happened to my old 200sx a week before smoking like hell.
Old Jan 13, 2004 | 06:14 AM
BstnLsVtec's Avatar
It does look like the turbo seals are blown but thats is not always the case. pull off the upper charge pipe and look in that and the intake manifold if there is oil buy a new turbo if there is no oil i suggest you get a bigger oil return line.
Old Jan 13, 2004 | 06:40 AM
mamaboy's Avatar
Default Re: What is wrong with my turbo? leaking oil? need help. (BstnLsVtec)
well by the the time you notice oil in your compressor......and find that all along your return is screwed up your in need of new seals and a rebuild
Old Jan 13, 2004 | 08:07 AM
igo4bmx's Avatar
blown seals..
good luck
navymike321
Aug 9, 2010 08:29 PM
CRXdan
Apr 4, 2005 06:28 PM
RACEPAK
May 25, 2004 09:07 AM
71 mgb
Nov 12, 2003 10:49 AM
blueturboteg
Sep 13, 2003 06:45 AM
