Question: Pulled off timing gear and crank pulley
Old Jan 12, 2004 | 07:12 PM
ITR9788's Avatar
Default Pulled off timing gear and crank pulley. Question on them.
I pulled off my timing gear off of my 97 R today. Before I put it back on, I went through my Helms manual and it says I should have a timing belt guide, which looks almost like a large washer, between the timing gear and the crank pulley. Do the R's have that, because the manual is for the GSR, and I dont have the R sup manual. Also, the small key that locks the pulleys in place with the crank looks too small. Am I only supposed to have 1 small one in there, about .25" long"? I had the timing belt messed with by a local shop before, and am starting to think they left something off. Thanks for any help.
Old Jan 12, 2004 | 07:44 PM
b19coupe's Avatar
Default Re: Pulled off timing gear and crank pulley. Question on them. (ITR9788)
There should be flat washers on both sides of the belt-on some lower gears the back washer is actually part of the gear. There should be two little crank keys-one for the lower crank gear, and one for the crank pulley.
Old Jan 12, 2004 | 08:06 PM
ITR9788's Avatar
Default Re: Pulled off timing gear and crank pulley. Question on them. (b19coupe)
Yea, the timing pulley has a built in washer on the backside. So I guess I need to buy a belt guide/washer for the front. And another crank key for one of the pulleys. Thanks.
Old Jan 12, 2004 | 08:55 PM
Dan GSR's Avatar
strange...that sound like a b16 gear
the b18 ones are different....from what i've seen
Old Jan 12, 2004 | 08:58 PM
TeamNextGenChris's Avatar
maybe this pic will help...from a 2000 R:
chris
Old Jan 12, 2004 | 09:22 PM
ITR9788's Avatar
Default Re: Pulled off timing gear and crank pulley. Question on them. (TeamNextGenChris)
That looks about right. #15 is what I have for the timing pulley, But my car was missing the frontside washer(#16). Why does the pic only show one lock key(#19). That thing looks way too small to lock both pulleys in place?
Old Jan 12, 2004 | 11:23 PM
Pondus's Avatar
Maybe you just need two #19's, one for each pulley?
Old Jan 13, 2004 | 03:33 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR9788 &raquo;</TD></TR><TR><TD CLASS="quote">That looks about right. #15 is what I have for the timing pulley, But my car was missing the frontside washer(#16). Why does the pic only show one lock key(#19). That thing looks way too small to lock both pulleys in place?</TD></TR></TABLE>
It requires two #19's. And they do look too small, but I guess that they are adequate to do the job.
Old Jan 13, 2004 | 06:07 AM
ITR9788's Avatar
Thanks for all the help guys.
Old Jan 20, 2004 | 02:51 AM
TurboLSVtecTeg's Avatar
I actually just had to order these parts. I picked up a couple extra 19's. Just incase I lose em. They are relatively inexpensive. BTW yea you need number 16 or the timing belt will start to slide off the cam gears. Not a good thing.
Achenar
Jan 12, 2008 01:50 PM
Jabinya
Aug 28, 2007 06:50 PM
doodooheadfart
Feb 21, 2007 03:47 PM
Sketch_hs
Mar 2, 2006 06:40 PM
DOHC_C-REX
Mar 24, 2004 11:51 AM
