balancing tires
Old Jan 12, 2004 | 03:00 PM
Neldawg's Avatar
Default balancing tires
Do you Accord owners balance your tires when you get them mounted? I'm contemplating if I should save a few bucks and have them just mounted and not balanced on my accord, cuz I am only changing two tires.
Is Balancing tires that important .....cuz people I know don't really do them but I just want to know since these tires are new
Thanks in advance
Old Jan 12, 2004 | 03:03 PM
The_Todd's Avatar
Farts in the shower
Default Re: balancing tires (Neldawg)
Yes for only a couple bucks more balance your tires....it will provide for a smoother ride, promote more even tire wear and alignment too....I got mine done at discount tire for 11 bucks rotated, balanced and mounted.
Old Jan 12, 2004 | 06:32 PM
jwogen1's Avatar
Default Re: balancing tires (VRDrvr)
definitely balance, align and rotate almost every time you change tires or switch out your winters vs. aftermarkets or whatever. it is always worth the extra few bucks
Old Jan 12, 2004 | 07:34 PM
Dave Slater's Avatar
One would think that new tires should be so symetrical that they should not need balanced, but that is not the case. I am like you and would rather not pay extra even if it is only a couple bucks per tire, so I have run used tires unbalanced on several cars. Frankly it was not worth the effort, the ride was not nice, and it ended up with increased maintenance costs for shocks and leaking drive shaft seals.
The manufacturers dont say that you need tires balanced and car aligned because the car will run safely without, but in practice you will achieve lower cost, a comfortable ride, and possibly a safer ride if you keep your tires balanced and your front end aligned.
Cars are a money pit. About the only place it makes sense to eliminate cost is on cosmetics. Keep the mechanical stuff up to snuff.
later, slater
Old Jan 12, 2004 | 07:41 PM
whoa its len 2's Avatar
I work at discount tire and do all my own stuff for free . Everytime a tire is mounted onto your wheel Id deffinatley have it balanced and air checked. All tires arent created equal and same goes for wheels. Its only a few bucks but youll be getting a smoother ride and even tire wear in return.
Old Jan 12, 2004 | 08:07 PM
iam7head's Avatar
Default Re: balancing tires (whoaitslen2)
you should be balancing it once a while, you can tell you will need it when you get on the highway
Old Jan 13, 2004 | 03:18 AM
KGAccord's Avatar
Default Re: balancing tires (iam7head)
i always figured it went without saying..when you mount a tire on a vehicle you should have it balanced.
unbalanced tire can suck depending how much out of balance it is, generally at speeds above 50 it can shake and vibrate the whole car.
Old Jan 13, 2004 | 10:54 AM
Neldawg's Avatar
Default Re: balancing tires (KGAccord)
ok
Thanks for the tips....
Its like $15 per tire around my way
But i guess i will do it
thanks again
Old Jan 13, 2004 | 10:58 AM
KGAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neldawg &raquo;</TD></TR><TR><TD CLASS="quote">ok
thanks again</TD></TR></TABLE>
if that's $15 with mounting,balancing, and new valve stems per each tire that's not too bad
Old Jan 14, 2004 | 04:36 PM
MCoupster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neldawg &raquo;</TD></TR><TR><TD CLASS="quote">Do you Accord owners balance your tires when you get them mounted? I'm contemplating if I should save a few bucks and have them just mounted and not balanced on my accord, cuz I am only changing two tires.
Thanks in advance</TD></TR></TABLE>
The few bucks you save by not balancing them will be far outweighed by the loss in tire life from uneven tread wear and alignment issues.
Cheers,
Michael
Old Jan 14, 2004 | 06:50 PM
The_Todd's Avatar
Farts in the shower
Default Re: balancing tires (MCoupster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MCoupster &raquo;</TD></TR><TR><TD CLASS="quote">
Cheers,
Michael</TD></TR></TABLE>
Old Jan 14, 2004 | 06:58 PM
ForceThis!'s Avatar
always balance your tires. period.
Old Jan 14, 2004 | 07:53 PM
KSTAR321's Avatar
Default Re: (ForceThis!)
I worked at a tire shop for nearly two years. During that time I must have balanced thousands of tires and I can count on one hand the number of times a tire/wheel assembly did not need any weights added to it. My recommendation would be to always have a tire balanced any time it is mounted on a wheel. - KC
Vtec04
Sep 26, 2017 03:31 AM
zak88lx
Mar 22, 2010 09:49 AM
climb_on
Jun 25, 2007 10:33 PM
businessmanph
Nov 7, 2005 12:57 PM
Cypher0117
11
May 5, 2005 05:44 PM
