VALVE ADJUSTMENT TOOL
Old Jan 12, 2004 | 01:37 PM
TOFU.man's Avatar
Default VALVE ADJUSTMENT TOOL
I was wonderin is there anywhere else to the valve adjustment tool for the B series motors besides honda i cant find it at auto zone or advance auto. Any help would be great. thanks
Old Jan 12, 2004 | 01:56 PM
99_SH's Avatar
Default Re: VALVE ADJUSTMENT TOOL (B16AHondaSi)
Snap-on sells it.
You can also call Keith at 800-441-6117. He's a sponsor at my preludeonline board and carrys any tools you can think of.
good luck!
Old Jan 12, 2004 | 02:25 PM
mmuller's Avatar
Mad Scientist
Default Re: VALVE ADJUSTMENT TOOL (99_SH)
or you can just heat up a 10mm with a torch and bend it to a L.
Old Jan 12, 2004 | 06:16 PM
hondamanwill's Avatar
I see alot of people looking for these I'll talk to my Tool guy. see if I can get a group buy or something
Old Jan 12, 2004 | 07:07 PM
Ryan C's Avatar
Default Re: VALVE ADJUSTMENT TOOL (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">or you can just heat up a 10mm with a torch and bend it to a L.</TD></TR></TABLE>
done it twice
Old Jan 12, 2004 | 07:16 PM
coos's Avatar
Default Re: VALVE ADJUSTMENT TOOL (Ryan C)
I use the Blue-point swivel gear wrench
Old Jan 12, 2004 | 08:48 PM
TOFU.man's Avatar
Default Re: (hondamanwill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanwill &raquo;</TD></TR><TR><TD CLASS="quote">I see alot of people looking for these I'll talk to my Tool guy. see if I can get a group buy or something</TD></TR></TABLE>
Thats cool im down for it. I mean honda wants 100 bucks for the damn thing.
Old Jan 12, 2004 | 09:01 PM
2FastxEg's Avatar
you can get one for cheaper on harbor freights website, its cheap and decent quality, and its only like 20-30 bucks
Old Jan 21, 2004 | 05:24 AM
dwnthehatch's Avatar
Default Re: (2FastxEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FastxEg &raquo;</TD></TR><TR><TD CLASS="quote">you can get one for cheaper on harbor freights website, its cheap and decent quality, and its only like 20-30 bucks </TD></TR></TABLE>
I thought they discontinued selling it. Do you have a part number?
Old Jan 21, 2004 | 07:24 AM
Zatar69's Avatar
Default Re: (dwnthehatch)
I just grabbed a 10mm wrench and hit it with my sledge over my jack (hard metal) until it was bent the required 90 degrees...works like a charm!
Old Jan 21, 2004 | 09:31 AM
Miles85916's Avatar
here you go sir
https://honda-tech.com/zerothread?id=557944
Old Jan 26, 2004 | 02:13 PM
sick64nova's Avatar
Default Re: VALVE ADJUSTMENT TOOL (Miles85916)
snap on sells them for 33 bucks i bought one on friday
Old Jan 26, 2004 | 03:45 PM
im_poor's Avatar
Default Re: VALVE ADJUSTMENT TOOL (sick64nova)
you sure its only $33? did you get it off the truck?
Old Jan 26, 2004 | 05:12 PM
sgee's Avatar
Default Re: VALVE ADJUSTMENT TOOL (im_poor)
I had pretty good luck with the Gear Wrench (ratchet with a hole in the head) from Sears. I used the 10mm socket and 3" extension to turn the locknut, with a screwdriver down the middle to adjust the set screw.
Best procedure I found was:
- loosen locknut and set screw
- slip in thicker of the two allowable feeler gauges (i.e. 0.007" for GS-R intake)
- adjust set screw
- finger-tighten locknut with socket+extension
- torque down locknut with ratchet.
For me, 75% of the time the torque-down would move the setscrew slightly; it would allow the thinner feeler (i.e. 0.006") to fit, but the 0.007" wouldn't anymore. Perfect!
Old Jan 31, 2004 | 04:50 AM
talked to the tool guy and it looks like 31bucks plus shipping. not a very good deal to me I'll keep looking for a better deal
Old Jan 31, 2004 | 08:36 AM
KUjonathan's Avatar
Default Re: VALVE ADJUSTMENT TOOL (hondamanwill)
does anybody ever have trouble using feeling gauges on the intake valves on the D-seies motor? the fuel injection wiring and stuff, along with other stuff back there really doesn't allow me to use feeler gauges like i've always used them... is there a honda trick that i'm not aware of? perhaps different feeler gauges?
jonathan
Old Jan 22, 2013 | 12:16 PM
leeo's Avatar
Amazon Amazon
-- $10.40 , can't go wrong...
Old Jan 23, 2013 | 03:10 AM
Maxcapacity's Avatar
Use a 3/8 10mm deep socket pressed in or welded on the box end of a 5/8 wrench. Easy and cheap to make, also - a flat head that will feed into the socket
proj21
Oct 1, 2009 02:40 PM
ViCtOr VaHn
Apr 4, 2007 03:58 PM
ITR198
Nov 23, 2005 02:52 PM
JETSPD1477
Oct 6, 2005 09:20 PM
SkRiBLaH
Apr 11, 2005 01:20 PM
