Clutch for Turbo
Should I go with a ACT Extreme Duty clutch or RPS Street Disc Max if I'm going to be making 300-350hp to the wheels with a gsr motor? I was looking for something full faced because this will be my daily driver. Driveability is more important than racing!
If not can someone recommend a good clutch?
considering you're only fwd, go for the act 2100, i've heard it's a great clutch for the money; there are many dsm guys in your boat that will use nothing other than the 2100. if you want some massive pedal pressure (and gripping power) then you might want the 2600.
https://honda-tech.com/zerothread?id=723662
https://honda-tech.com/zerothread?id=678700
https://honda-tech.com/zerothread?id=675493
https://honda-tech.com/zerothread?id=624819
https://honda-tech.com/zerothread?id=616793
https://honda-tech.com/zerothread?id=672320
The search button is located in the upper right hand corner of your screen.
b00stn
Nov 4, 2002 07:10 PM
