need some head info.
Hi guys I tried a quick search and couldnt find anything. Im in the process of building up my b16 head and I want to know EXACTLY
what kind of sensors and misc "things" I need that connect to the head. I was thinking about dizzy, fuel rail, fpr, and IM. I know there has to be more and I've come to ask my fellow h-t 'ers
Head:
Coolant temp sensor
Distributor
Another 1 wire sensor near coolant temp
IM:
IM
IACV
IAT
FPR/vacuum
Fuel Rail, 2 fuel lines
Inj's/o-rings
2 coolant lines on IACV
Bracket from IM to back of block
EVAP purge solenoid/vacuum
TB:
MAP
TPS
Throttle cable
Valve Cover:
Grommets
Gasket
Ground
Coolant temp sensor
Distributor
IM:
IM
IACV
IAT
FPR/vacuum
Inj's/o-rings
TB:
MAP
TPS
Throttle cable
Valve Cover:
Grommets
Gasket
Ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo »</TD></TR><TR><TD CLASS="quote">Head:
Coolant temp sensor
Distributor
IM:
IM
IACV
IAT
FPR/vacuum
Inj's/o-rings
TB:
MAP
TPS
Throttle cable
Valve Cover:
Grommets
Gasket
Ground</TD></TR></TABLE>
Thanks
Wish me luck on finding all of this
Coolant temp sensor
Distributor
IM:
IM
IACV
IAT
FPR/vacuum
Inj's/o-rings
TB:
MAP
TPS
Throttle cable
Valve Cover:
Grommets
Gasket
Thanks
turbotime
18
Nov 7, 2005 09:15 PM
