removing rod/piston pins
Old Jan 11, 2004 | 08:37 PM
crizmotek's Avatar
Default removing rod/piston pins
how is the piston pin removed, is there a special tool to hammer it out?
Old Jan 11, 2004 | 08:46 PM
jdmhatch94's Avatar
they are pressed out and heated up
Old Jan 11, 2004 | 08:49 PM
crizmotek's Avatar
Default Re: (jdmhatch94)
can you be more specific? how are they pressed out and why are they heated up?
Old Jan 11, 2004 | 09:01 PM
jdmhatch94's Avatar
in my honda service manual it has special tool that fits inside the actuall pin but the lip rest on the outer diameter of pin. i guess the heat if for the expanding/contracting of the metals...
Old Jan 11, 2004 | 10:09 PM
Altered's Avatar
Default Re: removing rod/piston pins (crizmotek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crizmotek &raquo;</TD></TR><TR><TD CLASS="quote">how is the piston pin removed, is there a special tool?</TD></TR></TABLE>
yes sir, its called a machine shop
j spec
Mar 13, 2007 09:22 PM
Master23
17
May 12, 2006 07:37 PM
Ekay Jay
Jun 2, 2005 07:16 PM
matttegra
Mar 11, 2005 10:57 AM
erniecars
Jul 16, 2002 12:08 PM
