Searched! D15B7= Bolt in/plug n play in an OBD1 CRX?
Old Jan 11, 2004 | 07:45 PM
4crx4me's Avatar
Default Searched! D15B7= Bolt in/plug n play in an OBD1 CRX?
Here's the deal, I can get a D15B7 for dirt cheap!
One of my CRX DX's has no compression, and I'm in the middle of wiring it for OBD1(future home of a B17). Can I just drop in the D15B7, in the meantime?
Are motor mounts the same?
OBD1 ECU and wiring just plug and play?
Old Jan 11, 2004 | 07:52 PM
VTECVillain's Avatar
Default Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (4crx4me)
Simply switch the driver's side bracket and mount on the D15B7 to the stock CRX bracket and mount and it'll bolt right in. Of course you'll need to reuse the CRX's cable tranny with upper and rear mounts. If you complete the OBD1 wiring, it will make the motor basically plug and play. When you go to put the B17 in, you'll only need to wire up the extra sensors like the VTEC solenoid, VTEC pressure switch, Knock, etc.
Old Jan 11, 2004 | 08:41 PM
4crx4me's Avatar
Default Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (VTECVillain)
Thanks, VTECVillain you continue to be my hero.
Old Jan 11, 2004 | 11:29 PM
Shadow Templar's Avatar
are u switching the head??? D15B7s arent vtec naturally i thought
Old Jan 12, 2004 | 05:39 AM
4crx4me's Avatar
Default Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (Shadow Templar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow Templar &raquo;</TD></TR><TR><TD CLASS="quote">are u switching the head??? D15B7s arent vtec naturally i thought</TD></TR></TABLE>
I know it's not VTEC, don't need it, yet. I just need an engine to get the car driveable, so my nieghbors don't lynch me. LOL
PS: I'm only paying $100.00 for it.
Old Jan 12, 2004 | 08:23 AM
Aint nothin wrong with D15B7, i have one, and i really like it. don t bother makin it a vtec tho, a cam change would do more for it. vtec ain t everything, speed is speed. obdi eh? cool ****. the only weird thing is it has a solid crank gear
Old Jan 12, 2004 | 11:44 AM
tgreaves's Avatar
If its a obd1 crx with a vtec ecu just go with a mini-me on it..
Old Jan 12, 2004 | 09:25 PM
Default Re: Searched! D15B7= Bolt in/plug n play in an OBD1 CRX? (tgreaves)
Z6 with a Y8 gasket should drop about a second of ur et time, according to another HT memeber (bauleycivic) if u read his ****, ull get a great idea on how to do it.
efjones9
Dec 28, 2008 11:56 PM
94b16teg
Feb 22, 2007 07:00 PM
sdpuck
Apr 12, 2004 01:39 PM
