B18c-5
Old Jan 11, 2004 | 06:58 PM
mxpx035's Avatar
Default B18c-5
What is the difference in 96+ spec type-r swaps for $3999
and the 98+ spec type-r swap for $4799
i was thinking the 4-1 header but that is not worth $800
so if any one knows i would apreciate the info because if the 98+ has better cams and the header i think i wouuld be better off getting that motor but i just want to justify my money if they are the same i will just get the 96+ spec motor swap
Old Jan 12, 2004 | 08:35 AM
car-toons's Avatar
Default Re: B18c-5 (mxpx035)
Your answer lies in the tranny, LSD vs. Non-LSD I believe. REDTOPROCKS!!
Old Jan 12, 2004 | 09:41 AM
(JON)'s Avatar
besides the 4-1 header you get a tranny that has a 4.7 final drive instead of a 4.4
Old Jan 12, 2004 | 07:04 PM
Kamin's Avatar
Default Re: B18c-5 (car-toons)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by car-toons &raquo;</TD></TR><TR><TD CLASS="quote">Your answer lies in the tranny, LSD vs. Non-LSD I believe. REDTOPROCKS!!</TD></TR></TABLE>
they both have LSD last i heard.
Old Jan 13, 2004 | 03:20 AM
b00sted93Hatch's Avatar
Default Re: B18c-5 (Kamin)
Both have lsd. I believe the 4.7 was only offered in 97.
Old Jan 13, 2004 | 05:00 AM
00 FBP ItR's Avatar
Default Re: B18c-5 (allMotor93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Both have lsd. I believe the 4.7 was only offered in 97.</TD></TR></TABLE>
98+ come w/ a 4.7 FD along w/ the JDM 4-1 header.
Old Jan 13, 2004 | 03:21 PM
mxpx035's Avatar
Default Re: B18c-5 (00 FBP ItR)
so in other words it is better to get the 98+ spec because of the final drive right
and will the 4.7 make my rpms on the highway lower or higher?
Old Jan 13, 2004 | 03:22 PM
KRiS1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 &raquo;</TD></TR><TR><TD CLASS="quote">so in other words it is better to get the 98+ spec because of the final drive right
and will the 4.7 make my rpms on the highway lower or higher?</TD></TR></TABLE>
Higher
Old Jan 13, 2004 | 07:44 PM
mxpx035's Avatar
Default Re: B18c-5 (KRiS1)
do you think that the 96 spec swap would be better because it is 800 cheaper and i can just buy the header or will the 4.7 make that much of a difference. I also do alot of highway driveing and i don't want my gears to be too short.
Old Jan 13, 2004 | 08:03 PM
iplaybass's Avatar
LSD. LSD? LSD! LSD......
Old Jan 14, 2004 | 12:19 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 &raquo;</TD></TR><TR><TD CLASS="quote">do you think that the 96 spec swap would be better because it is 800 cheaper and i can just buy the header or will the 4.7 make that much of a difference. I also do alot of highway driveing and i don't want my gears to be too short.</TD></TR></TABLE>
yeah, i'd personally go with the 96 just because you can buy a 4.7fd for under $400 and its a direct replacement the 96's 4.40 final drive. But it sounds like you dont need a 4.7 tranny anyways, as you state you do a lot of highway driving and a 4.7 fd would eat up some of your gas mileage vs. the 96 ITR tranny. The 4-1 is no biggy either.....421 is better anyways imo, you'll have better midrange power with the ITR's 421 manifold vs. a 4-1 header which is all geared towards top-end power.
One other perk of the 98+ ITR engine is that it would have less miles on it vs. the 96 engine.
Old Jan 14, 2004 | 06:25 AM
mxpx035's Avatar
Default Re: B18c-5 (Katman)
they all come with lsd right? and in about 6 months i plan on boosting it and building the motor so i think i am going to get the 96 spec i just thought there was a difference in the cams so i would have went 98+ spec
Old Jan 14, 2004 | 10:56 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxpx035 &raquo;</TD></TR><TR><TD CLASS="quote">they all come with lsd right? and in about 6 months i plan on boosting it and building the motor so i think i am going to get the 96 spec i just thought there was a difference in the cams so i would have went 98+ spec</TD></TR></TABLE>
All Type-R tranny's do, yes.
oh yeah, there is a slight difference in the camshafts between 95-97 & 98-00 ITR engines. 98+ ITR engines basically have CTR camshafts (3 degress more duration), whereas the 95-97 ITR cams specs have 3 degrees less duration. Just upgrade to CTR cams and you'll be 98 spec in the cam department.
Old Jan 14, 2004 | 11:24 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
oh yeah, there is a slight difference in the camshafts between 95-97 & 98-00 ITR engines. 98+ ITR engines basically have CTR camshafts (3 degress more duration), whereas the 95-97 ITR cams specs have 3 degrees less duration. Just upgrade to CTR cams and you'll be 98 spec in the cam department.</TD></TR></TABLE>
There is no such thing as a 95 Type R!!!
Old Jan 14, 2004 | 12:11 PM
Katman's Avatar
Default Re: B18c-5 (jh4dc23spoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh4dc23spoon &raquo;</TD></TR><TR><TD CLASS="quote">
There is no such thing as a 95 Type R!!!</TD></TR></TABLE>
uh, yes there is.
The Japanese Type-R debuted in mid 1995.
Old Jan 14, 2004 | 12:59 PM
Specail Ed's Avatar
If you want a B18 to boost, don't by a Type-R. First off you can save money by getting a GSR swap as opposed to the Type-R swap. If the perk of getting the Type-R is the LSD, a GSR swap and a Quaife will cost you less. Also, the 4-1 header shouldn't even be a concern if you are going to boost it because you won't even be using that header. The Type-R also has a higher compression ratio which isn't as condusive to boost as the lower ratio in the GSR. I'm not saying there's anything wrong with boosting a Type-R, but that motor is designed as a high reving, naturally aspirated motor. GSR swaps are definitely cheaper and easier to come by, and will probably suit your needs better.
Old Jan 14, 2004 | 06:55 PM
thad
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by car-toons &raquo;</TD></TR><TR><TD CLASS="quote">Your answer lies in the tranny, LSD vs. Non-LSD I believe. REDTOPROCKS!!</TD></TR></TABLE> the 96spec type r had cast exh manifold and std. LSD.
the 98spec had 4-1 tubular manifold (header) and the helical LSD. the 01 ITR had the same cams as the CTR the previous years suffered 3degrees duratation loss on the int cam.
Old Jan 14, 2004 | 07:46 PM
mxpx035's Avatar
Default Re: B18c-5 (thad)
i know people say it is better to start with a gsr but i want the type r tranny lsd which will come installed and i won't have to spend more to have it put in it has a good intake manifold, cams, i can also can sell any parts when i upgrade like the cams and manifold. and it will be fast n/a untill i can save for my boost.
Old Jan 14, 2004 | 08:27 PM
MEANB18's Avatar
If I remember right there is a small difference in the heads as well between the years. I remember someone talking about this a while ago, something about how the earlier heads flowed better due to being assembled and ported by hand and the newer ones were done by machine? I forget. stupid me.
I wish I could find the post, but there are a million people that have asked this SAME question.
alex_belarus
Dec 9, 2007 01:28 PM
importtuner07
Jul 17, 2006 08:35 AM
yomomz
11
Oct 29, 2004 03:08 PM
JDMluvR
Aug 13, 2004 08:00 AM
giff74
Dec 13, 2003 10:53 AM
