injector size in a turbo GSR 440s or 550s?
Old Jan 11, 2004 | 06:45 PM
smurfey002's Avatar
Default injector size in a turbo GSR 440s or 550s?
651
Modified by smurfey002 at 9:00 AM 6/29/2005
Old Jan 11, 2004 | 06:55 PM
racerx7's Avatar
Default Re: injector size in a turbo GSR 440s or 550s? (smurfey002)
Hondata and 880cc and your good for over 500whp
Old Jan 11, 2004 | 10:49 PM
turborsx9111's Avatar
Default Re: (smurfey002)
go with the 440 if you still plan to be daily driven
Old Jan 12, 2004 | 01:50 AM
rocket256's Avatar
got with precision 680cc inj.
Old Jan 12, 2004 | 02:05 AM
MiraiZ's Avatar
Default Re: injector size in a turbo GSR 440s or 550s? (rocket256)
Lancer Evo injectors!!! 560cc!!
Old Jan 12, 2004 | 03:06 AM
ekb18c's Avatar
for now I guess you should opt for the 550 cc.
Old Jan 12, 2004 | 06:21 AM
VTC_CiViC's Avatar
Default Re: injector size in a turbo GSR 440s or 550s? (ekb18c)
Has anybody actually tried running the hack with 550's? I've heard people really struggle to get the car to run well off boost but I don't know anybody personally who tried it.
Old Jan 12, 2004 | 11:20 AM
VTC_CiViC's Avatar
Once you build it up, you're gonna want the 550's in there, so it would suck to have to buy another set of injectors all over again, but 550's aren't gonna be easy to control on an AFC I can tell you that much.
Old Jan 12, 2004 | 06:50 PM
Humble Performance's Avatar
This dyno sheet was at 18 psi with 440 cc injectors , stock computer and a V-AFC.
Old Jan 12, 2004 | 07:19 PM
smurfey002's Avatar
ok yea. the 440's will be fine. thanks a ton for helping me make my mind up guys!!
Old Jan 12, 2004 | 07:21 PM
TRE_'s Avatar
i'm running 440's with no problems right now at 10psi..
Old Jan 12, 2004 | 07:23 PM
redboost10's Avatar
Default Re: (THE_HX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE_HX &raquo;</TD></TR><TR><TD CLASS="quote">i'm running 440's with no problems right now at 10psi.. </TD></TR></TABLE>
may i ask what your hp is?
Old Jan 12, 2004 | 07:49 PM
quick1racer's Avatar
Default Re: (tgh99si)
i am running an ls vtec, vafc, gm 3 bar, rc 550cc
i cant get it to run right it idles like crap and it if i mash the throttle down it responds like crap.
any suggestions on settings for midrange response
i'm thinking about putting 310 cc to get it drivable
it wants to idle way high almost at times to 4 g's i think it might be the idle control valve when i relocated the radiator for turbo i dropped it below the thermostat so it isn't completly full with coolent, so there is air in the system i am thinking maybe it is screwing with the idle valve
help help
help me please i have been trying to fix it for over a month
Old Jan 29, 2004 | 12:27 AM
guymosiris's Avatar
Default Re: (quick1racer)
IMO, you should just run DSM 450cc's which I heard are very Hack friendly, and are cheap, and then upgrade later when you're ready to tune with something better.
Old Jan 29, 2004 | 05:56 AM
dbang003's Avatar
Default Re: (guymosiris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quick1racer &raquo;</TD></TR><TR><TD CLASS="quote">i am running an ls vtec, vafc, gm 3 bar, rc 550cc
i cant get it to run right it idles like crap and it if i mash the throttle down it responds like crap.</TD></TR></TABLE>
wish i knew too...i am runnin b18c1, vafc II, missing link, and rc 550's. idles at 850 rpm or so, but have to baby it up through mid-range til i can start gettin on it...
what do u have the vafc set at for the lower rpm's? as soon as the snow gets off the road i think i am gonna put in some new plugs and set the afc to -50% up to about 3k rpm...once in boost the 550's seem fine...just hard to tune down low...will bring to the dyno to get tuned properly but have to make sure i can get it to make it there without foulin out 3 sets of plugs...
drew
DC2fab
Apr 9, 2010 09:31 PM
nboost
Oct 14, 2006 01:12 PM
Project_DX
16
Jul 30, 2006 08:09 AM
alexb16hb
May 13, 2006 10:18 AM
Arturbo
Jan 9, 2002 06:20 AM
