5 bolt turbo flange questions?!?!?
Old Jan 11, 2004 | 05:29 PM
gdrum's Avatar
Default 5 bolt turbo flange questions?!?!?
I have some 5 bolt flange turbo questoins. I recently purchased this 5 bolt flange.
And this is the turbo flange that i have pictures from my turbo.
Now either i orderd a jank flange or its not fitting up right. Please help me. Only 2 holes on the bottom fit right and the others are all next to the hole or off a bit. If that is a good flange then is my turbo just old or are there different 5 bolts to get. If you notice on my flange the low part....on my turbo its higher....more of a square then it is.
Can I use this flange anyways? Can I just get pancake sized washers on the top and crank it down and that will create a good enough seal? I think if i just get huge washers for the top part and crank it down and the washers will hit the edge of the flange it shold create a good seal but i dunno. Please all opinions and help is appreciated thanks.
Old Jan 11, 2004 | 05:37 PM
IHaveTurbos's Avatar
Default Re: 5 bolt turbo flange questions?!?!? (gdrum)
You got the Ford 5 bolt flange, and you need the Mercedes 5 bolt which is a larger bolt pattern. I already hooked another memeber on here up with the correct laser cut flange, if you want I can sell you one also.
Tim
Old Jan 11, 2004 | 05:44 PM
JonGP4's Avatar
umm is it just me or do i count 7 bolt holes on that turbo?
Old Jan 11, 2004 | 05:57 PM
RenoRacing's Avatar
Default Re: (JonGP4)
yup, mercedes in deed. here are both stacked on top of eachother.
Old Jan 11, 2004 | 06:13 PM
gdrum's Avatar
Default Re: (RenoRacing)
thanks for your help......thanks a ton...
Old Jan 11, 2004 | 06:16 PM
Default Re: (gdrum)
No problem, glad I could help you out.
Tim
Old Jan 11, 2004 | 06:35 PM
boostsohfast's Avatar
Default Re: (Speed-Factor)
I'm helping a friend of mine piece together a kit and I'm not sure which discharge flange I need. The turbo is a garret T3 super60 with a .48 exhaust housing. I had one flange and two of the holes lined up like this guys and the other three were off. Anyone sure of what flange I need and where I can get it??
Thanks and sorry to hijack the thread.
Old Jan 11, 2004 | 06:38 PM
gdrum's Avatar
Default Re: (boostsohfast)
yeah thats how mine fit, i was so mad to, because after all time/money i have put into this and to not have something work right...grr but thanks to HT for helping me figure it out
Old Jan 11, 2004 | 06:52 PM
Replied to your PM.
Tim
Old Jan 12, 2004 | 12:38 PM
Orders Sent, Thanks again guys. If there is anything else I can help you with just let me know.
Tim
Old Sep 7, 2004 | 07:28 PM
TokuiAutowerks's Avatar
do you have anymore of those t3 mercedes style flanges? ive bought 2 different styled t3 flanges so far and none has fit because i guess they are the ford style ones. i really need one
Old Sep 8, 2004 | 09:55 AM
RenoRacing's Avatar
Default Re: (TokuiAutowerks)
I believe that Kteller8 has some of the mercedes wide five t3 flanges. Shoot him a pm and see, very good guy to deal with!
Jesse
W O T TWO
Dec 11, 2009 04:07 PM
bambbrose
Apr 10, 2006 07:41 PM
BDaTurboTeg
May 27, 2005 07:24 PM
streetlvlhatch
Feb 29, 2004 05:35 PM
