compression test on a zc sohc vtec...results!
Old Jan 11, 2004 | 05:04 PM
gloryhog's Avatar
Default compression test on a zc sohc vtec...results!
I have noticed my car running a little weird so i did a compression test and ...
cyl.#1- 185
cyl.#2- 185
cyl.#3- 225
cyl.#4- 220
heres the thing the spark plugs on cyl. 3+4 have a dark color ( the insulator and the iridium tip) my exaust smells like maybe unburned fuel or oil.what would you think this is? by the way it has a fresh valve job , y8 head gasket, fuel press. at 38 at idle, timing is adv. 2degrees, I personally thought it was pistons 3,4 blowing by, but hell who knows, could be the head gasket!!!!
Old Jan 11, 2004 | 05:56 PM
8200RPM's Avatar
local hippie
Default Re: compression test on a zc sohc vtec...results! (gloryhog)
maybe the head gasket around cylinder #1 & 2... or rings..?
Old Jan 11, 2004 | 08:05 PM
blackeg's Avatar
Default Re: compression test on a zc sohc vtec...results! (8200RPM)
the #'s are nice and high, but the variance is ehh. since you have low compression between 1 &2 cylindars and not 3 and 4 i would be lead to believe there might be something up with the headgasket between the 2 low cylindars
Old Jan 11, 2004 | 10:58 PM
mmuller's Avatar
Mad Scientist
Default Re: compression test on a zc sohc vtec...results! (blackeg)
try putting a little bit of oil in cylinder #1 and 2 so see if compression goes up. If it does, well you know whats wrong.
If not do a leak down test, that will pinpoint the problem.
Old Jan 13, 2004 | 06:01 PM
gloryhog's Avatar
well if you think its 1+2 w/ the leak I would have thought that it was 3+4 because the plugs had a slight touch of oil or something on them every time i pull them out. plugs 1+2 are clean, man I think its fixin' to get forged pistons total seal rings , polished crank , that should fix it...
Old Jan 13, 2004 | 06:13 PM
Kendall's Avatar
Default Re: (gloryhog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gloryhog &raquo;</TD></TR><TR><TD CLASS="quote">well if you think its 1+2 w/ the leak I would have thought that it was 3+4 because the plugs had a slight touch of oil or something on them every time i pull them out. plugs 1+2 are clean, man I think its fixin' to get forged pistons total seal rings , polished crank , that should fix it...</TD></TR></TABLE>
I don't see how a polished crank could effect compression (hint: sarcasm), but everything else .
Old Jan 13, 2004 | 07:13 PM
gloryhog's Avatar
the polished crank was something i was going to do while i was building the bottom end , so there would be no chance of it snagging a bearing , I have heard that many people do this on high reving motors. your right though it has nothing to do w/ the comp.
Old Jan 14, 2004 | 06:20 PM
gloryhog's Avatar
I DID ANOTHER COMP. TEST TONIGHT AND THE NUMBERS WERE MUCH BETTER
CYL# 1 - 200
CYL# 2 - 210
CYL# 3 - 220
CYL# 4 - 220
I DID NOTICE THAT THERE WAS A BLACK SCORCHED SPOT ON SPARK PLUG NUMBER 4 IT WAS VERY SMALL BUT i THINK IM RUNNIN KINDA LEAN.
bvillarreal
Aug 22, 2013 09:43 PM
rxbahamut
Oct 17, 2011 06:33 PM
Boostn B20
11
Nov 27, 2008 01:22 PM
Mr_ET
Jul 31, 2007 01:07 PM
racingant
Dec 6, 2005 08:03 AM
