ls/vtec fan switch
Old Jan 11, 2004 | 05:04 PM
turbohondask's Avatar
Default ls/vtec fan switch
On the b18b blocks the fan switch is by the the thermostat housing. for the 90 integra the switch is on the back of the block is the switch interchangable by changing the connector on the 90 integra and use the one on the b18b block? Do they use the same method of connection? Ground switch
Old Jan 11, 2004 | 05:26 PM
Turbogixxer's Avatar
Default Re: ls/vtec fan switch (turbohondask)
Yes, just get a neck from a B18b and put it in.
Old Jan 15, 2004 | 10:54 AM
Default Re: ls/vtec fan switch (turbogixxer)
thank you
DrewBrews
Dec 23, 2011 04:01 AM
85
Sep 3, 2006 03:02 PM
Du_Ma
Jun 14, 2003 12:19 PM
