ALL INFO NEEDED!!!!
I am about to sell my hatch, so its time to get some info on a good shell for my H22 project. I want to use a 94 teg LS. But I also am thinking of buying another hatch. I think there is maybe 200-300 pounds difference in weight, but the the look of the teg is a beautiful thing. what do you think fellow tuners??
There is no perfect trim. Some trims have options that you may want, some do not. The lightest trims are cx/vx. followed by dx, then the pig SI. Si has all the cool things, like sunroof, rear discs, etc. But it weights a lot more.
When I go looking for a hatch, I first check to see if the frame it straight. It will be hard to do a H22a swap with a bent frame. I would not care about the miles, cause you are going to do a motor swap.
https://honda-tech.com/zerothread?id=150315
hope that helps.
hope that helps.
importdays
Aug 23, 2005 08:41 PM
