t25 install need help with water lines
Old Jan 11, 2004 | 03:17 PM
Soccerking3000's Avatar
Default t25 install need help with water lines
ok i am going to install a t25 turbo but i do not know the best place to install the water line for the turbo if someone could help me out that would be great, pics to please i have a 93 si with d16z6, i know where to put the "t" connectors for the oil and everything but the water lines i dunno where to put
thanks in advance
Old Jan 11, 2004 | 03:41 PM
Bailhatch's Avatar
Default Re: t25 install need help with water lines (Soccerking3000)
waste of time IMO. more stuff to leak with no real advantage. Get a turbo timer and just run oil.
Old Jan 11, 2004 | 03:46 PM
Default Re: t25 install need help with water lines (Bailhatch)
okay good cause it would be really hard to do thanks a bunch anyone else have any opinions
Old Jan 11, 2004 | 04:31 PM
tilt's Avatar
I moved the line from the coolant hose going to the throttle body to the turbo, and from the turbo to the tb.
Old Jan 11, 2004 | 06:18 PM
Default Re: t25 install need help with water lines (tilt)
that sounds easy enough
Old Jul 28, 2004 | 06:22 AM
Curtis2kul's Avatar
so really i dont need water lines on my d16 homemade setup as long as a let the car run for around 60 sec at idle before i cut it off?
Old Jul 28, 2004 | 06:30 AM
beepy's Avatar
Default Re: t25 install need help with water lines (Curtis2kul)
No, but do you want to have to let the car idle for that long every time you drive it?
Old Jul 28, 2004 | 09:19 AM
dunkd's Avatar
water lines arent neccassary, simply optional.
Old Jul 28, 2004 | 10:02 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">waste of time IMO. more stuff to leak with no real advantage. Get a turbo timer and just run oil.</TD></TR></TABLE>
Agreed. The water cooled option is supposed to prolong the turbo's life, but tons and tons of set-ups used oil-cooled turbo's and they last for 80,000+ miles no problem. As far as the turbo timer goes, it's good to allow the oil to cool down before shutting the car off when a long drive has taken place or when you introduced the motor to a heavy load. This prevents oil from coking up inside of the oil lines and oil housing of the turbo.
Old Jul 28, 2004 | 10:08 AM
EKhothatch's Avatar
The Greddy Turbo Kit for the D16Z6 - TD04H-15g doesn't have water lines. I would say don't worry about it. Just make sure to let her cool down.
h23vtec_dc2
Feb 28, 2010 04:47 PM
Soccerking3000
Mar 1, 2004 08:28 AM
Accord94DX
Apr 27, 2003 12:31 PM
adhana2
Apr 25, 2003 04:51 PM
silverpenny
Apr 23, 2003 05:51 PM
