For Those Running with Skunk2 Stage II Camshafts
Old Jan 11, 2004 | 12:39 PM
All-Motor H22A's Avatar
Default For Those Running with Skunk2 Stage II Camshafts
For those of you guys running w/ Skunk2 Stage II Camshafts and got it turned, what settings are you making the most power?
Mine Right Now is
Intake Side +2 Degrees
Exhaust Side 0 Degrees
Old Jan 11, 2004 | 05:30 PM
specalk's Avatar
Default Re: For Those Running with Skunk2 Stage II Camshafts (All-Motor H22A)
bump i would also like to know
Old Jan 11, 2004 | 06:45 PM
Daboi630's Avatar
so how much power are you making?
Old Jan 12, 2004 | 05:27 AM
Default Re: For Those Running with Skunk2 Stage II Camshafts (Daboi630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 &raquo;</TD></TR><TR><TD CLASS="quote">so how much power are you making? </TD></TR></TABLE>
No idea yet. I haven't tuned my car. Right now I just been playing w/ cam gear settings and my FPR. So far, I haven't been happy with the power of the Skunk2 Stage II. The power feels like it comes on too late. But once I have enough money to purchase a Hondata unit + Tuning, I'll keep you guys updated.
Old Jan 12, 2004 | 09:02 AM
ludefreek's Avatar
i have been told the type-s cams give just as much power as the Skunk cams do. anyone heard this as well. i havent seen dyno comparison sheets or anything, just heard this from a couple of ppl.
Old Jan 13, 2004 | 10:24 AM
Default Re: (ludefreek)
That might be possible on a stock block, but I'm sure with a bump in compression w/ a built block such as 11.5:1 Compression maybe even higher, the Skunk2 Stage II will show more gains.
Old Jan 14, 2004 | 12:18 AM
ranta18's Avatar
Default Re: (All-Motor H22A)
Try retarding the exhaust. That helped out a lot with my Crower Stage 2's. -3 for me.
Old Jan 14, 2004 | 08:07 AM
NXLude's Avatar
Type S cams make no where near the power of any stage 2 cams. Type S will make about 5 hp. They dont have enough duration to make much power
Old Jan 14, 2004 | 09:03 PM
Default Re: (ranta18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote">Try retarding the exhaust. That helped out a lot with my Crower Stage 2's. -3 for me.</TD></TR></TABLE>
You also have the intake side on +1 right?
Isn't that a lot of overlap? No problems w/ the valves hitting each other?
Old Jan 14, 2004 | 09:14 PM
supaZZZleepa's Avatar
skunk 2 stage 2 are a lot better...you dont get that much out of type s...dont mean to hijack your thread but does anyone have jun stage 3 cams? i want to know how those are. sorry for the hijack
Old Jan 14, 2004 | 11:03 PM
ranta18's Avatar
My setup was Type-S pistons and a 0.020 milled head. Thats 11.6:1 compression. I actually had the cam gears at -5 and -1, to give about -3 exhaust and + 1 intake when taking the milled head into account (0.012=1deg+). When I first put the motor back together I accidentally had both cam gears retarded a tooth and there were no pistons hitting valves. Goes to show how much you can move them. The intake is iffy. I messed around with it and didn't seem to gain any power by adding or subracting anymore. It might make more power when advancing it, but thats because it leans it out more, when you have to adjust the fuel it doesn't increase it overall. The engine made 8 whp alone when I retarded the exhaust to -3.
Old Jan 27, 2004 | 12:38 PM
Thanks for the input Ranta, but the cam profiles are different between the two cams. But you're using +1 and -3 huh? The overlap on that isn't too much?
I usually don't see street cars w/ an exhaust cam retarded so much.
Old Jan 27, 2004 | 01:25 PM
ranta18's Avatar
Thats what works for the Crower's I guess. Both Crower and Import Builders said retarding the exhaust 2-3 degrees would help. I'm not sure on the Skunk2's though.
lopaka07
17
Jul 23, 2005 12:33 AM
tunedek
Feb 4, 2004 02:35 PM
JDM2ndGen
Aug 15, 2003 03:59 PM
JunIntegra
Apr 12, 2003 04:16 PM
warwagon
Feb 22, 2003 08:26 AM
