T3 60-1 or SC61S?
Old Jan 11, 2004 | 09:35 AM
Altered's Avatar
Default T3 60-1 or SC61S?
Im trying to decide what turbo to go with for my build, its a 10.0:1 2.0 LS/VTEC
B18B1 Block:
GE Sleeves
84mm 10.0:1 Arias Pistons
Crower Rods
B16A Head:
Extensively reworked head (Done by me of course )
Portflow valve job
Supertech valves
Eibach EVS valvetrain
Crower 63401T cams
I was originally planning on a mild 1.8 build and a SC61E turbo but I recently decided to just go all out and make the best of my build up.
I will be driving the car everyday at about 12 PSI and plan on taking it to about 22 PSI at the track. The overall goal for this project is 400WHP @ 12 PSI and around 500+WHP and low 11's at the track @ 22PSI.
Now, the 2 turbos I have been in constant debate over are the T3 60-1 or the SC61S. I need to know in your opinions, which I should go with and why? Which will make the most power at the above boost levels?
If possible, could you guys list guestimated or if you have either one of these turbos actual spool times, HP output with either and any pics you may have. I honestly cant decide, I need a little convincing
Old Jan 11, 2004 | 10:00 AM
E-Rok's Avatar
EPIC TUNING
Default Re: T3 60-1 or SC61S? (Altered)
SC61 is a t3/60-1 but with a much better and efficient design.
Old Jan 11, 2004 | 10:06 AM
AVATAR's Avatar
Default Re: T3 60-1 or SC61S? (rewsnaeht)
ask yourself "do I want the better GT compressor wheel or not?"
Old Jan 11, 2004 | 10:07 AM
Altered's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewsnaeht &raquo;</TD></TR><TR><TD CLASS="quote">SC61 is a t3/60-1 but with a much better and efficient design.</TD></TR></TABLE>
I thought it was a T3/T04(E/S)???
Old Jan 11, 2004 | 10:09 AM
E-Rok's Avatar
EPIC TUNING
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altered &raquo;</TD></TR><TR><TD CLASS="quote">
I thought it was a T3/T04(E/S)???</TD></TR></TABLE>
nope.
Old Jan 11, 2004 | 10:15 AM
Altered's Avatar
nope.</TD></TR></TABLE>
learn something new everday
Old Jan 11, 2004 | 10:20 AM
Bnjmn's Avatar
SC61 will spool slower, but have more HP and be better for the strip.
Old Jan 11, 2004 | 10:29 AM
Altered's Avatar
Well, After talking to SixtyDashOne (thanks for the info!) Ive decided to go with the SC61S
Old Jan 11, 2004 | 10:34 AM
Odiedogcx's Avatar
AIRBORNE
Default Re: T3 60-1 or SC61S? (Bnjmn)
I thought the SC61 spooled better, because it has the stage 5 wheel, and the t3/60-1 has the stage 3 wheel?
Old Jan 11, 2004 | 12:53 PM
Bnjmn's Avatar
Default Re: T3 60-1 or SC61S? (Odiedogcx)
a smaller exhaust wheel will spool better than a larger exhaust wheel. Barring any aerodynamic differences.
The larger wheel will allow more horsepower up top.
Old Jan 11, 2004 | 04:00 PM
GOLDBERG's Avatar
why not try the full race t3/t67....close if not the same spool as the sc61 and well..flows 75lbs/min..
Old Jan 11, 2004 | 04:15 PM
boosted92's Avatar
Default Re: T3 60-1 or SC61S? (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">why not try the full race t3/t67....close if not the same spool as the sc61 and well..flows 75lbs/min.. </TD></TR></TABLE>
A T67 compressor wheel and a T3 exhaust wheel is a horrible missmatch, I can't see that working well.
If it were my car, I'd run a GT3561. It's basically an SC61 but with a GT exhaust wheel as well, for even quicker spool.
Old Jan 11, 2004 | 04:19 PM
Jcr1982's Avatar
Default Re: T3 60-1 or SC61S? (boosted92)
A friend of mine has an SC-61 on a GTI 1.8t and its a truely awesome turbo
Old Jan 11, 2004 | 04:25 PM
10seceg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altered &raquo;</TD></TR><TR><TD CLASS="quote">Well, After talking to SixtyDashOne (thanks for the info!) Ive decided to go with the SC61S</TD></TR></TABLE>
good choice
Old Jan 11, 2004 | 05:27 PM
vod's Avatar
vod
boosted92: so the GT3561 is the same as a GT35E?
Old Jan 11, 2004 | 05:33 PM
h22 civic's Avatar
Default Re: (vod)
Old Jan 11, 2004 | 06:26 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
If it were my car, I'd run a GT3561. It's basically an SC61 but with a GT exhaust wheel as well, for even quicker spool.</TD></TR></TABLE>
well....look at the dynos and say that again?
Old Jan 11, 2004 | 06:27 PM
GOLDBERG's Avatar
Default Re: (h22 civic)
and why is it such a horrible mismatch?
jaydim
May 7, 2007 05:13 AM
projectPSI
Nov 18, 2005 10:23 PM
BIG RICH
Nov 28, 2004 01:14 PM
NoBoost
Dec 18, 2002 09:30 PM
