The simplest explanation is usually correct.
Old Jan 11, 2004 | 08:36 AM
sketcherton's Avatar
Default The simplest explanation is usually correct.
I leave my girl's house this morning and discover that my car sounds like a lawnmower. Worst sound ever.
There was zero ***** at all (it wouldn't go above 60k) and the whole motor was shaking. I could feel it up into the shift even.
After the most embarassing drive ever (people everywhere literally were stopping and pointing as I went by), I go into my friend's shop and we check under the hood. We think it's the exaust manifold gasket is pooched or somethng with the manifold, so we tighten it up cause a few bolts were loose for starters.
That doesn't work, and by this time I'm picturing dollar signs just flying out of the engine. Then, we're both looking in trying to see if there's anything else loose or something small like that before we go to the trouble of taking off the manifold, and one of the wires with the plug falls out of the block. One of my plugs had just fallen out. Weird.
Put it back in. Nothing was stripped, but that fixed the problem. All the other plugs were in tight. Has anyone else ever had a plug just come loose and fall out? Seemed pretty fluke to me.
After a ticket yesterday, I'm pretty stoked that another large bill/pain in the *** didn't fall into my lap.
Old Jan 11, 2004 | 09:31 AM
The_Todd's Avatar
Farts in the shower
Default Re: The simplest explanation is usually correct. (sketcherton)
Well depending on what type of plug it was....maybe, over time with road vibration bumps etc things can loosen and thats usually why they make stops on all plug connection (at least my car does its a 90). That is kinda weird, but at least you got it fixed without $$$$$ flying out of your pocket.
Old Jan 11, 2004 | 01:05 PM
StimpyBoy's Avatar
Do you mean a spark plug + the wire? If a spark plug came out, the car would indeed run like ***, have no ***** and sound horrible.
If you're positive it wasn't stripped, then it probably just wasn't torqued down properly. But you'd better watch out for the next little while. You were lucky the plug didn't shoot through the hood or something
Old Jan 11, 2004 | 02:40 PM
Default Re: The simplest explanation is usually correct. (StimpyBoy)
I'm starting to suspect that perhaps the plug was "helped" loose. It's not stripped and everything else was in tight.
My girl's ex lives across the street from her, and he's a douchebag like that. I'm ******* pissed.
Old Jan 11, 2004 | 04:45 PM
1994AccordSiR's Avatar
go return the favor to him, if you know he is the one who did it
Old Jan 11, 2004 | 11:19 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StimpyBoy &raquo;</TD></TR><TR><TD CLASS="quote">If you're positive it wasn't stripped, then it probably just wasn't torqued down properly. But you'd better watch out for the next little while. You were lucky the plug didn't shoot through the hood or something </TD></TR></TABLE>
i shot a spark plug outta my block. it put a reverse ding in my hood.
it was wierd, sound like a v8 that is running shitty.
i went and popped my hood and #2 plug and wire were half way out. i put it back in and tighten all the other down to make sure they werent gonna do the same thing.
havent had a problem yet.
Old Jan 12, 2004 | 06:20 AM
Mike813's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sketcherton &raquo;</TD></TR><TR><TD CLASS="quote">I'm starting to suspect that perhaps the plug was "helped" loose. It's not stripped and everything else was in tight.
you should be suspecting why he is still near your girl or under her car? but maybe that idiot forgot to tighten one if he was trying to help out, buttttt 4 slashed tires usually does the job for me if you hate on someone :]
*i take no responsiblility if u get caught ;x* but gluck! revenge is a bi$ch..
6000pounds
Dec 18, 2008 07:30 AM
fleetmack
Jul 18, 2005 10:08 AM
greenDC2
15
Dec 16, 2004 07:25 PM
BLKCRX
Jan 2, 2003 01:32 AM
ToneyTigre
Dec 20, 2001 01:20 PM
