tps sensor question, need help
Old Jan 11, 2004 | 03:47 AM
jennifermike's Avatar
Default tps sensor question, need help
i did a search but didnt come up with any thing. code 7, tps, is on in my 95 gsr. i dont know if its bad, is there a way to check? also i saw a post that all tps sensors are the same so if its bad i could use a sohc non-vtec one from like a 95 lx? please hel
Old Jan 11, 2004 | 05:39 AM
Mikey3000's Avatar
Default Re: tps sensor question, need help (jennifermike)
you can use any obd1 tps. there is a way to check if its bad. you need a helms to troubleshoot the problem.
Old Jan 11, 2004 | 08:04 AM
mmuller's Avatar
Mad Scientist
Default Re: tps sensor question, need help (Mikey3000)
check the voltage, it should be .45 and around 5 volts
sdboostin111
Dec 3, 2008 04:14 PM
Dohcvtec59
Dec 8, 2004 08:01 PM
hondaeg8
May 14, 2004 10:23 AM
jennifermike
Jan 30, 2004 09:32 PM
