problem with 95 gsr, help?????
Old Jan 30, 2004 | 05:17 PM
jennifermike's Avatar
Default problem with 95 gsr, help?????
my wife has a 95 gsr. 2 weeks ago it was throwing a number 7 cel code. so we got the t-body replaced with a JG Edlebrock one. tonight we were out driving and the cars went crazy. this is what happened, my wife was driving at about 45-50 mph. the car lost power then went normal, this happened 6 or 7 times. i saw there was no cel, then it came on, number 7 again? WTF. and last week the cel was on for about 20 minutes but went off. can someone give me some insite?
thanks
Old Jan 30, 2004 | 06:13 PM
Default Re: problem with 95 gsr, help????? (jennifermike)
up
Old Jan 30, 2004 | 06:19 PM
Kendall's Avatar
Check the throttle position sensor, it's a likely candidate for your problem. I'm not sure what a code 7 is on an OBD-1 GSR though. It may be the MAP sensor.
Old Jan 30, 2004 | 06:22 PM
Default Re: (Kendall)
it is the code for the tps, its f-ing new but im gunna look in to it tommorow
Old Jan 30, 2004 | 09:32 PM
b19coupe's Avatar
Default Re: (jennifermike)
You may have a bad connection somewhere. If you already replaced the TPS, chances are it's in the wiring. There is also an off chance that it's the ECU.
EJ1Shifty
10
Nov 20, 2018 08:59 AM
luis1855
Apr 3, 2010 09:12 PM
beany
Nov 21, 2005 08:32 AM
Forrest Gump 9
Apr 26, 2005 09:05 PM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
